trouble fitting main body Options
Steve279021
#1 Posted : 22 December 2015 20:19:32
I have got to the stage where I am fitting the main body but it won't sit down properly, it seems to be getting caught on the fuel filler cover panel where the aerials are mounted. Had anyone else come across this?
Dodge charger build complete
Senna lotus 97t complete
JD4EVER
#2 Posted : 22 December 2015 20:48:36
I had this problem too,
In the end I removed that black round part,I can't remember what's its called ,and it went down OK after that .
I then reglued that part once I had everything in place.
I also made sure the screw holes in the bodywork were properly aligned with the black brackets on the floor of the model by using a large needle before I started screwing everything together which worked really well.
Steve279021
#3 Posted : 22 December 2015 21:53:31
Well I took it off again then put it back and it seems to have gone on ok this time. Maybe something was catching it so hopefully it was just me! Anyway it's back off now as I forgot to put the turbo inlets on!
This page was generated in 0.033 seconds.
