 Rank: Elite     Groups: Registered
Joined: 26/04/2014 Posts: 1,510 Points: 4,442 Location: Essex
In the instructions it says to just use a piece of double sided to hold it on. Could a dab of glue be used instead? Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Dodge charger build complete https://forum.deagostini....1686229545.1.1.utmcsr=(direct)|utmccn=(direct)|utmcmd=(none)&__utmv=-&__utmk=9709046 Senna lotus 97t complete https://forum.deagostini...id.googlequicksearchbox|utmccn=(referral)|utmcmd=referral|utmcct=/&__utmv=-&__utmk=37308643
You'll need to use a canopy glue such as formula 560 as superglue will fog/damage the screen
Would plastic glue not work or should I just stick to the instructions and use the double sided? Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
Hi Steve You can use something like this to attach the screen its what I used to do it http://www.ebay.co.uk/sc...ue+n+glaze&_sacat=0
It looks like PVA glue to start with but dries clear. Regards Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Steve279021 wrote:Would plastic glue not work or should I just stick to the instructions and use the double sided? Great care is going to be needed, it could end up looking unsightly and no going back once you've applied it.
I decided not to chance it in the end and went for the double sided route in the instructions. Senna mclaren mp4/4 build complete mp4/4 build http://forum.model-space...spx?g=posts&t=12029
