pin pushing tool Options
WildRover
#1 Posted : 15 January 2016 12:22:02
Let's imagine that someone is stupid enough Blink to "misplace" LOL his pin pushing tool, where can i buy one at a reasonable price? Even fleabay are looking at £12+..or is there a better method? (Mainly for planking hulls, etc)
Completed: Earth, Moon, Sun Orbiter
Build a Model Solar System
Under Constuction: HMB Endeavour
HMS Victory
Mitsubishi Zero
Tiger Tank
D51
#2 Posted : 15 January 2016 12:35:01
BigGrin hi WildRover I don't use a plnpusher I drill a small hole into the plank and use a needle nose pliers to push home
Hope this helps rgd Martyn
WildRover
#3 Posted : 15 January 2016 12:59:01
thats certainly cheaper! Laugh im guessing a micro (0.5mm) drill bit to make the hole just to stop the wood splitting?
HMS Victory
Mitsubishi Zero
Tiger Tank
D51
#4 Posted : 15 January 2016 13:00:18
Hi there WildRover
Like Martyn, I rarely use a pin pusher, preferring to drill and tap in with a jeweller's hammer.
If you do want an alternative however, check in the tool section on ebay and look for a draper panel pin pusher - it's a heftier version of the pin pusher and there's one on there for £5.99 with free p&p.
They're not quite as accurate but will do the job.
WildRover
#5 Posted : 15 January 2016 13:03:47
Thanks Robin, yeah that seems to be the way to go, especially with the hull, as i only want it to hold the planks until the gorilla glue dries! I got the pin pusher with the endeavour, and it came in handy, just sometimes had a tendancy to damage the wood underneath if it forced the nail thru too hard.
HMS Victory
Mitsubishi Zero
Tiger Tank
D51
Guest (7)
This page was generated in 0.104 seconds.
