HELP PLEASE Options
dave210
#1 Posted : 03 October 2010 21:29:50
Rank: Beginner Level 1
I'm having difficulty constructing the second deck.
Having added the deck support's and the deck.
I've now found that i cant fit the support beam into the space left, if anyone has had the same problem or can think of the best way to remedy the problem please e-mail me.
#2 Posted : 03 October 2010 21:40:08
The middle deck beams are a very snug fit to start with, have you followed the info to chamfer the edges of the beams, and they sit upright against the frames.
dave210
#3 Posted : 03 October 2010 21:54:24
yes I've followed all the instructions and advise to the letter. However i'd need to sand off 5mm at least to make it fit. i cant see what gone wrong
riff-raff
#4 Posted : 03 October 2010 22:00:38
Do you need to remove 5mm across the length of the support beam or just in places? If the 5mm just needs to be removed from the end then it should follow the natural curve of the boat. If the 5mm needs to be removed from the length of the support then there may be an error.
If you can post images then please do so. If you have a mobile with camera then you could email them to me and I can upload them for you
Built:
dave210
#5 Posted : 03 October 2010 22:10:34
I need to remove around 5mm along the whole beam which is what has stumped me so much.
the deck supports and deck all fit and look correct and as they should be. i am trying to up load pictures however as always im having tech problems haha
#6 Posted : 03 October 2010 23:40:45
I had the same situation you could as suggested in the mag sand down the beams to get the correct fit but it is a long winded job. i marked the rib positions and filed out little cuts with a square file to help the beams fit snug in position. you don't want to force it as it will distort the rib positions.
hope that helps
jaseSneaky
willz
#7 Posted : 03 October 2010 23:56:14
Active Service Medal: 500 post active service MedalTurquoise Medal: Turquoise Medal for model making know-how contributionOutstanding Build: An award for an outstanding buildBuild-Diary Medal: Build-Diary Medal of Honour
I havent got that far yet but I have all my gun support beams here, and some are 5 mm wider than the others, presumably for different deck so have you got the beams mixed up
daffy09
#8 Posted : 04 October 2010 14:20:45
Hi Dave210
If you have made an error, its likely that I have as well, but I think it's inlikely!
I had the same problem as you and came up with the same answer as Jase.
I offered the beams up, marked the position of the ribs, and then filed out with a
small square needle file. Everything looks 'right' with them fitted so hopefully it won't be a problem.
Hope this is helpful
Happy building
Daffy09
z8000783
#9 Posted : 04 October 2010 14:31:49
Groups: Unapproved
Can you point to where that is please, I think I missed it. Looking at the official build diary the beam appears to touch the rib at the top but is adrift at the bottom. Is that not correct?
John
#10 Posted : 04 October 2010 16:32:10
Have a look at pages 10/11/12 of issue 19 which covers the installation of the middle deck gun beams, which is very similar to the installation lower deck gun beams.
z8000783
#11 Posted : 04 October 2010 17:09:25
Groups: Unapproved
Thanks but I can't see where it tells you to chamfer the edges. The bottoms of the beams are up to 5mm away from the rib on the middle deck because of the inward sloping angle of the rib. I presume the beams should sit upright.
John
dave210
#12 Posted : 04 October 2010 17:49:11
hi all, thanks for all your advise. having read it all i plan to sand out shallow hollows to fit the beam into position using a square file as i had thought about that as a solution. hopefully it will work ok and not affect the rest of the build. i'll up date in a few days with how i get on.
thanks again
dave210
