32 Pages «<2425262728>»
tf64 Spitfire Build Options
alemo
#501 Posted : 05 March 2016 11:20:11
Nice neat job as always.
Like your rivet marking on the metal components, good to know the marking tool is still working well nearing the end of the project.
Looking forward to the next update.
Regards, Alec
Adapt, improvise, overcome.
#502 Posted : 05 March 2016 11:31:02
Looking good Trev, very nice work indeed!!BigGrin BigGrin
#503 Posted : 05 March 2016 11:38:31
Lovely work as always Trev, I'm really enjoying this build of yours!! Drool Cool ThumpUp
Have a very enjoyable days modelling Trev and I'm really looking forward to seeing all that sheet metal fitted - well done!! Cool Cool ThumpUp
#504 Posted : 05 March 2016 15:06:13
Very nice job Trev, those rivets look like they would be tedious work but by the looks of it you haven't let that put you off as they look spot on Cool
#505 Posted : 05 March 2016 17:53:00
Trev,
Very nice to see it coming along so well.
See the offer on the kit today and must admit to being tempted but not sure if i would be very good at adding all that rivit detail as i guess you only get the one try per piece.
Hope it continues to go well.
#506 Posted : 05 March 2016 20:05:59
Hi Alemo,
Thanks for looking in, as for the Rivets once you start you realise that a lot of thoughts about riveting are soon lost, when you start and you will find that your confidence will grow, in fact the riveting I now do is all free hand.
More soon.
Trev
#507 Posted : 05 March 2016 20:07:54
Hi Nem,
Thanks for your comments.
Trev.
#508 Posted : 05 March 2016 20:10:11
Hi Kev,
Had a good day on the Spit will update Sunday.
Trev
#509 Posted : 05 March 2016 20:14:38
Hi Dave,
I must say that Riveting seem's to me as one of those jobs that one slip and you are found to be speaking Queens English.
Trev.
#510 Posted : 05 March 2016 20:19:11
Hi Tony,
Thanks for your comments, be tempted with your skill level you will love it, a great kit just waiting for you.
Trev.
#511 Posted : 06 March 2016 11:32:55
UPDATE:SPTIFIRE.
060316.
TAIL RUDDER SECTION.
REAR LIGHTING WIRE.
TIP: Metal Plates: Make adjustments to fit before riveting this is very important or you can lose them if you adjust afterwards.
Rudder section after making adjustments to the metal plate to fit, also shows where I have cut out a small section of wood to allow lighting cable to fit.
Metal plate rivet marked and ready to be glued in place, also shows a check fit to cable.
Remove cable and clamp plate to set 24 hours.
Final picture with metal plate and rear lighting in place.
Next will be Tailfin and Stabilisers.
Thanks for looking.
Trev.
#512 Posted : 10 March 2016 09:52:36
UPDATE:SPITFIRE.
100316.
METAL PLATES TO ELEVATORS.
This shows the Rudder and Elevators complete with metal plates, fitted top and bottom with rivet markings.
This shows Tailfin/Elevators/Rudder with metal plates fitted.
The next part will be to make slits to fit hinges into the tail rudder and stabilisers.
Trev.
#513 Posted : 10 March 2016 11:12:49
Fantastic work Trev ThumpUp
#514 Posted : 10 March 2016 11:27:34
Trev
That looks brilliant and its certainly a kit for the skilled model maker of which you clearly are.
Hope the rest if the build goes well.
alemo
#515 Posted : 10 March 2016 15:34:43
That looks terrific, you must be well pleased with the way that it's shaping up.
Regards, Alec
#516 Posted : 10 March 2016 15:43:48
Simply stunning work Trev, you have to be well chuffed with the way this is turning out......Love Love .. Keep those great pics coming......Cool Cool
#517 Posted : 10 March 2016 21:17:34
Hi Trev,BigGrin
The tail end looks spot on, as does the rest of your build.Cool
A credit to your skill and patience for the time put in.
Love Love Love
mark 2
#518 Posted : 11 March 2016 06:39:42
Hi Trev BigGrin .
Your spit is looking fantastic and the rivet detail is amazing Drool .
Keep up the awesome work.
Best regards.
greyhawk
#519 Posted : 11 March 2016 10:25:50
DaDokta
#520 Posted : 11 March 2016 10:46:27
As i said multiple times - loving your build and learning a lot!
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
