 Rank: Pro  Groups: Registered
Joined: 30/04/2015 Posts: 263 Points: 795 Location: Los Angeles
[quote=adriuus]yeah...it powers the supplied board....if you look at some of my posts on my build diary you'll see how I've integrated it all to suit how I want to finally display it http://forum.model-space...sts&t=16124&p=6[/quote] Yea, I had seen that. I have the same connectors and plan on using the supplied board in conjunction with my board. Time to do some more playing.
Joined: 16/03/2016 Posts: 122 Points: 381 Location: Layton, Utah
Colson...would you mind sharing your technique for getting the cracked leather look that you displayed on the passenger seats in post #3? Thanks! If at first you don't succeed,
maybe you should skip the chainsaw juggling...
GoofyFoot wrote:Colson...would you mind sharing your technique for getting the cracked leather look that you displayed on the passenger seats in post #3?
Thanks! I got that effect from doing a darker brown wash over the light paint before it had completely dried. I wasn't expecting it to crack like it did, but it worked well. Gives it a cool look.
colson wrote:GoofyFoot wrote:Colson...would you mind sharing your technique for getting the cracked leather look that you displayed on the passenger seats in post #3?
Thanks! I got that effect from doing a darker brown wash over the light paint before it had completely dried. I wasn't expecting it to crack like it did, but it worked well. Gives it a cool look. It does indeed! Were those acrylic, or oils? If at first you don't succeed,
Tamiya acrylics.
Tamiya acrylics. Nice! Once again proof that there are such things as happy accidents! I'm really loving your entire build by the way. I'm still debating on whether or not to do fiber optics on mine, but you've definitely got me thinking about it. If at first you don't succeed,
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,421 Points: 22,573 Location: Northamptonshire, England
Great work, as ever. The work you have done on the interior is excellent. Tried my hold area with the frame on over the weekend and too was pleased with what you will be able to see. Well done Regards Markwarren (Mark) Admin
Joined: 05/03/2015 Posts: 561 Points: 1,713 Location: South Carolina
Look awesome Colson! Got a question... I love what you did with the cockpit corridor hallway wall lights... what kind of clearance is there between the outside of the wall tube and the upper hull? Is there enough room between the two for wiring of those lights are did you have to do something creative?
I originally had LEDs there in LED holders, but the regular LEDs did keep the upper hull from going into position. So I pulled them all and replaced them with SMD LEDs. I just glued the wires to the side of the corridor then covered it all with black electrical tape to secure them and insulate. Here were some of them attached before finishing. They are extremely small and fragile to work with.
That's what I was thinking. I was worried that the hull would be too close to the corridor that there wouldn't be much room there. That is a pretty good solution!
LrdSatyr8 wrote:That's what I was thinking. I was worried that the hull would be too close to the corridor that there wouldn't be much room there. That is a pretty good solution! Well, you can see from my photos that it works quite well when lit. The other corridors I left with the standard LEDs because they fit fine. It was just the long corridor that I had to change out.
Colson you are just hitting this build out of the park.Are you sure you are not just sneaking onto the set on Episode 8 and taking photos?!
Cant wait to see the next installment.This is a masterful piece of modelling.
Joined: 08/02/2015 Posts: 274 Points: 812 Location: Malmesbury
looking fantast Giving me lots of ideas for when I get round to start my falcon. Cant what for the next update keep up the good work. Regards Shaun Building-RC spitfire Build- titanic,Skyrider drone, solar system, T72 tank
Lovely work Colson
Nice work, looks like a full size film set. Brilliant. Mark Regards Markwarren (Mark) Admin
Looking great bro! Love the new photos!
Joined: 10/05/2011 Posts: 204 Points: 631 Location: Morayshire
Lovely job of the gunner photo etch set, still waiting on mine. I just don't like the supplied gunners seats, may go down the 3D printed route. This is the fourth time I have been through this build thread and I still find bits that I think I missed on the previous times, keep up the great work Bob Regards Bob Builds in progress
1/12 Spitfire (Deagostini) 1/8 McLaren (Deagostini) 1/16 Stuka (Hatchete) 1/16 Zero (Deagostini)
