Loose front wheel bearings Options
Steve279021
#1 Posted : 20 April 2016 17:29:15
I have just fitted the front bearings and wheels onto the axles and the bearings on 1 of the wheels are quite a loose fit in the wheel. So when the wheel is bolted onto the axle it is quite wobbly. Has anyone else come across this?
Dodge charger build complete
#2 Posted : 20 April 2016 17:53:34
As you paying catch up, its always a good idea to first check the previous discussions
http://forum.model-space...aspx?g=posts&t=7700
The upshot is (and after many have now completd and run their RB7), there has not been a problem as a result of a slight sloppy fit of the wheel bearings.
Steve279021
#3 Posted : 20 April 2016 18:17:11
Ok. Thanks Mr T. I have read it now and I might try the ptfe route and see how that goes.
#4 Posted : 20 April 2016 20:15:51
PTFE tape often works, but ensure that it's even otherwise it will create wheel bounce.
Aquanin
#5 Posted : 20 April 2016 20:31:39
I ave found the loose bearings not to be a problem at all when running the car. Everything works great.
This page was generated in 0.098 seconds.
