4 Pages <1234>
Michaels USS New Jersey Options
#21 Posted : 28 January 2016 08:55:05
Looming great. What a difference PE makes to detail on ships. I dont build now without it.
Chris
michael.rolph
#22 Posted : 13 June 2016 21:47:23
It's been quite a while since my last update, I'll have to pull my finger out if I hope to get the ship finished this year.
After my last post davetwin sent some advice on adding the photo etch. I didn't realise that the parts had tiny tabs to lift the pieces off the model, I have now purchased a small etch bender to help me with the remainder of the parts.
Guns
The final two guns were assembled, I first attempted to base coat the part using the air brush but I was unsuccessful in getting anything resembling a consistent coat. The air brush was replaced with a can of Citadel Corax White from games workshop, then painted with Revell aqua colour paints
michael.rolph attached the following image(s):
michael.rolph
#23 Posted : 13 June 2016 21:48:28
Hull and deck
The rudders and propeller shafts were added to the hull and primed white. The hull was painted with multiple thinned down layers. I had difficulty getting a straight line when using masking tape as the paint kept bleeding through in several areas. The solution I found (on a random imgur post) was to paint over the masking tape with the paint colour it is protecting.
Picture 1-3
The deck was painted and then the stick on deck components were added
Picture 4-6
The deck was then glued in place and the propellers painted and added.
Picture 7-8
michael.rolph
#24 Posted : 13 June 2016 21:50:19
Display Stand
The provided stand was assembled and painted. I may replace this later depending on how happy I am with the finished product.
michael.rolph
#25 Posted : 13 June 2016 21:51:20
Super structure base
The componets of the superstructure base were cleaned up and assembled. I used liquid green stuff from Games Workshop to fill in small gaps between the pieces.
Picture 1-3
Some parts had to be removed to make way for some PE parts.
Picture 4
Once base coated and painted the stick on deck pieces were applied.
Picture 5
michael.rolph
#26 Posted : 13 June 2016 21:52:22
Tower
The sections of the tower have been assembled and primed.
#27 Posted : 14 June 2016 07:54:10
Great work Micheal. Your doing a great job. Its coming along now.
Chris
#28 Posted : 14 June 2016 15:24:46
Looking really nice
#29 Posted : 14 June 2016 15:44:41
She`s looking great Micheal!!!! how did you get on with the air brush? regards Phil
#30 Posted : 14 June 2016 18:52:31
Lots of very nice work being done here Michael, she's coming along very nicely....
#31 Posted : 14 June 2016 20:18:19
Looking good
#32 Posted : 14 June 2016 21:31:03
Wow, you certainly got your fair share of flash in that kit, looking great though.
Interested in how you find working with the liquid green stuff?
michael.rolph
#33 Posted : 15 June 2016 09:47:27
My first attempt with the air brush using thinned down citadel paints lasted about 30 seconds before the paint clogged the brush.
I switched to the aqua colour base paint and attempted to undercoat the hull, blocked nozzle after a few seconds, tried thinning it and it puddled on the surface.
After undercoating with the citadel spray I attempted to put down the base grey but again I had issues with blockages and pooling. I did manage to get the mix and air pressure correct at one point but the coverage was poor. I may try again in the future (i'll have to buy a cheap kit to test on) but I'll have to try to airbrush specific pains to see if I can get a better result.
michael.rolph
#34 Posted : 15 June 2016 09:55:54
The liquid green stuff is quite good to work with, you don't have the mixing prep time you get with solid green stuff or milliput. Its liquid enough to get into the small cracks and the excess wipes off easily and doesn't tend to drip.
#35 Posted : 15 June 2016 16:34:09
Hi coming along very nicely, do love the battle ships, look forward to your progress cheers mick.
#36 Posted : 16 June 2016 14:24:03
HI Michael.
Looks a great kit. look forward to seeing your progress Ian.
#37 Posted : 16 June 2016 21:00:16
Many thanks will giv it a try
michael.rolph
#38 Posted : 15 August 2016 19:46:54
Hi everyone, it's been a while since my last update. I've just finished moving house so everything’s been a bit hectic.
The following updates are for work I did before my move, hopefully I'll be able to start modelling again this week.
Entrance
This section sits just behind the bridge. The plastic doors and platform were removed and replaced with PE.
michael.rolph
#39 Posted : 15 August 2016 19:47:57
Funnel tops
Both pieces were removed and the unwanted platforms around the back and sides were removed. Multiple holes were drilled around the circumference of the funnel and the centre section removed.
Picture 1-2
The PE sections were added, this was the most difficult PE to add so far as the pieces didn't fit together easily. Two pieces of etch formed cross shape that should have dropped into the top of the funnel but it was slightly too large and required a lot of work to get to fit.
Picture 3
michael.rolph
#40 Posted : 15 August 2016 19:49:00
Main Gun Detector
The pieces and PE were removed. The plastic supports for the detector were removed. The replacement PE supports were added and some PE railing glued in place. The instructions called for holes to be drilled into either side of the detector and for it to be held in place with PE pins, these pins were too small to pick up and position correctly so the detector was glued in place.
Guest (7)
4 Pages <1234>
This page was generated in 0.634 seconds.
