Quad Turret Modification Detail... I though that it would be nice to have some of the inner workings of the turret, so after looking at cutaway drawings etc I set out to make up this area. It might not be accurate but I’m happy with the outcome. Once again 1mm plasticard was used and then parts from tank and F1 kits to make up the detail (kitbashing).. Gold was achieved by using some easter egg foil. Spencer Warthog attached the following image(s):
Another update and work continues on the top hull section. A lot more details, scratches, more dents to be added and streaks etc. The back base coat is for when the top coat is applied after then using a small dremmel tool to carefully scratch away the paint making the scratches more realistic rather than using paints. On the original Prop, Black plastic was used on a lot of the model to give the dents and scratches a sense of depth to them. More detail work is being added to the engine area and a section to work on has been made using plasticard. Once again some scratch building will come in to play as was done on the top turret section using cross section books as a reference. Spencer Warthog attached the following image(s):
Here is an update on this build... yes it's been a long time and still a long way to go but getting back into this to get my mojo back.. This is going to be photo heavy I'm afraid but hopefully you can see where this is going and what's involved.. about 99% scratchbuilt.. Warthog attached the following image(s):
Forgot how good this build was progressing.... Great to see an update, looking fab.... Regards Alan
 Looks better than ever and nice work Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,421 Points: 22,573 Location: Northamptonshire, England
Glad to see this updated and you back on it again. Looks stunning so far. Mark Regards Markwarren (Mark) Admin
Thanks for the encouragement guys To continue with the interior build, the walkway up to the cockpit needed some detail so more scratch building and original pads added.. Spence Warthog attached the following image(s):
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,888 Points: 17,816 Location: ipswich
That's just mind-boggling. It makes you want to be small enough to actually wander around in there.
Roy.
Rank: Administration  Groups: Administrator, Administrators, Forum Support Team, Global Forum Support, Global Forum Support Team, Moderator, Official Builds Joined: 24/08/2009 Posts: 1,943 Points: 5,841 Location: UK
Kinda makes me want to just jump on mine...
Joined: 10/09/2018 Posts: 42 Points: 129 Location: Texas
HOLY FREAKIN CRAP! You rock! I'm so glad I never saw this part of your build because I would have thrown my model in the trash...you win!
Clay
Thanks again guys for the kind words.. HyperdriveOnce again this is scratch built using plasticard and some aluminium tube. Spence Warthog attached the following image(s):
Main EngineWarthog attached the following image(s):
So glad you are back on this.Stunning work so far
Wonderful skills being shown, outstanding throughout..... Regards Alan
Stunning work Spence, superb skills on show. Mark Regards Markwarren (Mark) Admin
WOW is not a big enough word I know but DAM!!! your good at this, I haven't even opened up any of my packs yet and I'm already thinking how the......
Really looking forward to seeing a lot more of this build :)
 I'd forgotten just how good your build was, so pleased to see you’re back with it Superb, just superb
Joined: 31/01/2020 Posts: 13 Points: 39 Location: Wichita, KS
Ah, the build that is inspiring me to scratch out a full interior for my Falcon!  Fantastic work so far, and I can't wait to see it completed!
 Rank: Newbie  Groups: Registered
Wow, this is the most decent looking Falcon I've ever seen. Nice job!
