a bit of a problem Options
JAW
#1 Posted : 02 November 2010 10:48:10
Rank: Beginner Level 3
Hi All
I have just finished the 5th row of planks and hit a bit of a snag. It state in the instructions that planks should be proud on the gallery support. On mine this works on the starboard side but on the port side I am about 5mm to low.
I could easily fix this by adjusting the plank on row six, but I am concerned that this may cause me problems at a later stage.
Any advice you could give would be greatly appreciated.
Thanks again
JAW
yorkieboy1
#2 Posted : 02 November 2010 11:06:56
hi jaw it sounds to me as if the stern gallery isn't square if the rib that the gallery supports sit in is not exactly square this will account for the drop to one side. When I did mine I had a fault in that the slot the rib sits in on the false keel was not cut deep enough so i stripped everything down and then found what the problem was hope this helpsit may be an idea to strip it back but wait and see if anyone else has a solution
Peter
#3 Posted : 02 November 2010 12:12:57
Check that the gallery correctly seated, can you post a photo?
