 Rank: Pro  Groups: Registered
Joined: 27/07/2010 Posts: 122 Points: 363 Location: Rugby
Hi all I have proberly done something wrong here but x and y axis is not working z works fine i was wondering if the head is too tight but really need advice before i try anything. Everything seems to be ok though other than that and all software has been installed,i have followed instuctions carefully but still stuck. Thanks in advance Paul Paul
Current builds: 1/24 Spitfire 1/48 Apache Longbow Titanic Lifeboat
 Rank: Vice-Master       Groups: Registered
Joined: 07/01/2015 Posts: 856 Points: 2,479 Location: Sevenoaks, UK
Is it indeed stuck (is there any indication that the motors do try to move the head) or rather it seems they are not receiving the signal at all? Any images I post on my personal builds are free to be used and shared under Creative Commons Attribution license, which means you can do what you want with them, on the condition you mention I'm the author.
Happy building :-) http://www.model-space.com/gb/
there is no movement at all just one motor shuddering a little a bit of noise i think they are receiving the signal Paul
I will get back to you in the evening when I have a look at mine and try to understand what might be causing it. I guess you have already checked the obvious stuff: whether you can move the head by hand, are the slider blocks not blocked by anything, etc? Also make sure the screws securing the pulleys on the motor shaft are screwed in securely. Any images I post on my personal builds are free to be used and shared under Creative Commons Attribution license, which means you can do what you want with them, on the condition you mention I'm the author.
Paul, I think it might be a dodgy motor. You could try removing it and testing by connecting to some other lead (best would be Z axis lead as you know this works). If it still does the same, then you'll have to contact customer services and order a replacement. Please let me know how it goes. Cheers, Michu Any images I post on my personal builds are free to be used and shared under Creative Commons Attribution license, which means you can do what you want with them, on the condition you mention I'm the author.
Thanks I will try that later just got in from work need some sleep 1st Paul
Update I removed the head rods and reconnected the printer and everything works properly which it was what i was thinking that the rods was too tight, so now i need to get them lined up better as i think it was my error on lining it all up correctly. back to the drawing board it is then as they say. Paul
Great stuff , I found lining up the rods with the belts by looking directly down on each one a help with lining up and to see where they are out Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
