Joined: 24/05/2015 Posts: 43 Points: 109 Location: Adelaide
Trev,looking at your tail area your elevators, did u have to take a few mills off the elevators to fit, looking, at your markings on the plates near the rudder end it is same as mine after I had to take off about 4mil. max
To save your question being missed, you should place this post as a question in trevs build diary in reply to the relevant post on this
Joined: 13/02/2011 Posts: 2,243 Points: 6,849 Location: East Sussex
Hi Max001, Apologies for the delay, in answer to your question regarding the elevators, yes I did have to make small adjustments to each side to ensure of a good fit, this is as all builds are different, then after checking the fit I rivet marked them. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
