Nice work. The blood red colour certainly looks the part.
Lovely work Carl, now comes the fiddly part of populating the deck with all those sub assemblies.
She's heading to be a stunner Carl, great work...
Red looks spot on to me, excellent work!
Certainly looks like the right colour to me as I used anti fowl on the hull of my boat Rgd Martyn Building ? Completed. Soliei Royal . Sovereign of the Seas . Virginia . Scotland . San Felipe . Corel vasa , Santisima Trinadad X section , Vasa Next Build ? When sailors have good wine, They think themselves in heaven for the time. John Baltharpe
thanks everyone. Now on to the decks.The detail set came with printed "wooden" decks with an adhesive backing.I have read nightmares about getting these decks to stick so it was with some trepidation that I started this.The first job was to remove all of the cut outs on the deck for the deck furniture. I then peeled off the adhesive backing cover and slowly stuck the deck down.I had to us a toothpick to make the deck lay flat around the raised deck details, but it went pretty smoothly and it looks really good. The next step is to put the main deck piece on.I am doing a bit of weathering on the holes for the anchors first and then I will apply the deck and add the MANY small details on the deck. darbyvet attached the following image(s):
There a beggar to put on right and you have done a fine job Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Lovely. Those wood decks are so thin they are "scarey" but you have done a top job with this one. Hope the rest of the build goes well. Happy Modelling
Looks great, you've certainly done a great job with the deck... Well done...
The decks look great Carl.
I used the MK1 on my Yamato, I've just had a look and it's still all stuck down nicely, it was applied as is with no other glue.
I have read of a method of neaturilising the glue on the deck, I forget the method for this, then sticking the to the model using artists medium as the glue. I'll see if I can find it again.
The deck looks fantastic, great work!
davetwin wrote:The decks look great Carl.
I have read of a method of neaturilising the glue on the deck, I forget the method for this, then sticking the to the model using artists medium as the glue. I'll see if I can find it again. hopefully it wont start peeling up like some people have seen.The glue backing is really sticky-it was quite a job to remove the backing paper.The gun turrets really help to lock in the alignment. Carl
Nice work Carl, that wooden deck really brings the model to life - very well done.
Kev
Don't know how I missed this, awesome work my friend Ken's the name modeling's the game.
Cheers Kev and Ken. So the forward portion of the deck is now applied.This was a bit trickier than the aft section because of the anchor chain races.I had to go really slowly to prevent the deck from breaking as I was applying the decking around the anchor chain races.This decking material is actually a bit stronger than it looks.I am now in the process of painting the deck details (tons of them) and I have started work on the main turrets. Carl darbyvet attached the following image(s):
Excellent work with that decking, looks great. Graeme
It's definitely a nerve racking process getting the deck on but as you can see the end result is really worth it. She looks awesome.
Looks wonderful now you have got to this stage. Happy Modelling
Thanks everyone.
SO a little digression whilst I am waiting for the nine bazillion deck pieces to dry.
Vallejo paints.
I am using Vallejo paints for most of this model.These are acrylic paints that come in small squeeze bottles.They have 2 different types of paint.Their model color range is designed for brush painting and their model air range is airbrush ready ie you dont need to dilute it in order to airbrush rather than brush paint.
I have used both types of paint on the Arizona. They are highly pigmented,dry VERY quickly and provide excellent coverage.
The model air paint was used for the lower hull and bootstriping. This paint is excellent.it sprays very well through my Grex airbrush using the 0.5mm tip.It dries very quickly and it doesnt cause much tip clogging.I used a cotton bud dipped in water to keep the tip clog free.I found 2 or 3 coats will cover very well.The paint seems to adhere well to the primed plastic.I masked over the paint to paint the bootstriping and didnt have any paint coming off with the tape.
The upper hull was painted with the model color paint since the color I needed isnt available in the model air range.
The model color paint is VERY thick.Vallejo recommends diluting it a bit even if you are brush painting. The MINIMUM dilution for airbrushing is 1:1 with either distilled water or the Vallejo airbrush thinner.
I tried using the model color paint without dilution with my 0.7 mm tip and even under high pressure it just sputtered globs of paint out.
I diluted it 1:1 with the airbrush thinner and it sprayed fine through the airbrush-No sputtering and it provided nice and even coverage.I also used some Vallejo flow improver.This supposedly helps with flow and tip clogging.1 drop into the airbrush cup is all you need.My usual rule of thumb with thinning paint for airbrushing is to thin it until it is the consistency of milk.The 1:1 diluted Vallejo paint was just about that consistency.
I did have some tip clogging with the model color paint-even when it was diluted.I kept a wet cotton bud and every minute or so I would clean off the tip.You could hear the hissing nose from the airbrush change as the tip clogged.
I think part of the problem is that the paint dries very quickly so you have to be careful about clogging.
It does take 24 hours for the paint to cure.Acrylics dry form the outside in so if you are not careful and handle the part too soon it will smudge( ask me how I know).
If you let the paint cure for at least 24 hours it is a pretty durable finish, however it doesnt seem to be as robust as the model air paint and I have some touch up to do after appyling some of the painted parts to the model.
I have done some brush painting with the vallejo model color paint. I put some paint on a palette and diluted it with water from the brush.It covered well and dried quickly.There were some visible brush marks, but overall it was pretty easy to use.I think the Games workshop paints are better for brush painting because you see fewer brush marks with those.
So thats my Vallejo paint experience.
The next stage of the build is to add all of the deck details and then gradually add on the superstructures to the deck.
A very interesting and useful review of your experiences with Vallejo paints Carl and one which I'm sure will be very much welcomed by a lot of modellers?
Well done and thanks for taking the time to share it with others.
Kev
