 Rank: Pro  Groups: Registered
Joined: 23/09/2009 Posts: 138 Points: 422 Location: Surrey
I think you'll find that you use the sharp side of the blade for bending planks, but you remove the pad that the blade lands on. With the pad in you can use it for cutting planks. I have a photo, if I can work out how to upload it Mark attached the following image(s):
Certainly not the case with the bender I have, in fact if the strike pad is removed the blade does not even reach to the other side be it the blunt or sharp side, therefore with the benders I have, the pad has to be in place and the blade swopped round depending on need, if I recall rightly my benders are Amati not Artesania, which also have a set of additional shaped strike pads, but regarding the bender with the tool set your right.
Joined: 21/03/2010 Posts: 54 Points: 158 Location: ISLE OF MAN
I have been away for some time and have got a bit behind every one else. However trying to get back on course, I have started the planking , on 4 th row but I have managed to snap one of the planks, is there any spare planking supplied. I will probably be able to use the broken ones later when a shorter piece is required. If I do manage to break more which I probably will is there any suppliers that anyone may recommend.
Joined: 26/09/2010 Posts: 851 Points: 2,565 Location: Walsall
Hi James Cornwall Model Boats is a good lpace to get parts from. I ordered some extra planking and it was delivered the next day. http://www.cornwallmodelboats.co.uk/index.html
The link above is to there site. Hope this helps Foz
Thanks Foz that is a great help, maybe I am not the only one that has snapped their planks
Joined: 25/04/2010 Posts: 748 Points: 2,285 Location: bognor regis
Mark wrote:I think you'll find that you use the sharp side of the blade for bending planks, but you remove the pad that the blade lands on. With the pad in you can use it for cutting planks. I have a photo, if I can work out how to upload it your exactly right mark ..pad in for cutting ..pad out for bending cheers benny
Joined: 15/04/2010 Posts: 1,266 Points: 3,841 Location: The Quantock Hills,Somerset
I've been using them to bend with the pad in so that the planks don't get damaged..oh dear,in the words of one of the great Dick Emerys characters"Dad,dad,I done it wrong again dad!" Rob Nolli Illigitimi Carborundum!!!Current Builds: HMS Victory, SV Thermopylae
