9 Pages <1234>»
Micks aka Mogwai C57 build diary Options
#21 Posted : 27 July 2016 15:59:32
Hi thanks for looking in.and your comments, much appreciated. Yes dave enjoying this very much.it's a great quality kit to build.
STAGE 9
sees us glue the side steps to the posts, then screw to front.glue in the grab posts.and the drain tap on the front.cheers mick.
#22 Posted : 27 July 2016 16:09:58
Hi Mick,
This is coming on at a grand rate and looking good.
WTG
#23 Posted : 27 July 2016 16:18:22
Hi STAGE 10 , 11, AND 12
sees us start the chassis all screwed together really well.and fix the cylinder plates to the front.this completes pack 2. Of a very enjoyable build.cheers mick.
#24 Posted : 27 July 2016 17:43:08
All looking very nice.
I must admit i like the pre-painted finish on this one.
My D-51 is still some way from completion with the last set of parts being the tender wheels.
Over the time of the build some of the brass has tarnished so i will have to paint but its a daunting looking task.
Glad you are enjoying your new build.
#25 Posted : 27 July 2016 18:04:32
I am glad I went for this, it looks amazing!
#26 Posted : 27 July 2016 23:18:46
Looking good Mick.
TIMBERWOLF
#27 Posted : 27 July 2016 23:43:44
very nice build
#28 Posted : 28 July 2016 16:39:28
Looking good Mick
I noticed that already this is starting to weight a fair bit with every part so far being metal
#29 Posted : 29 July 2016 14:09:15
Hi thanks for all those that left comments, much appreciated. The paintwork on this is superb quality. You won't be disappointed for one sec nem. Cheers mick.
#30 Posted : 29 August 2016 16:10:22
Hi pack 3
Stages 13/20
First of all stage 13 the safety valves and motion bars, all glue together this stage.all fits very well. Cheers mick. Last pic stage 14 the piston rods and cylinder covers.
#31 Posted : 29 August 2016 16:16:38
Stage 15, the cylinder side plates.glue the bits to the side plates and attach with screws. All again went together really well.cheers mick.
#32 Posted : 29 August 2016 16:21:04
Hi sorry bit out of order, but forgot to upload pic of the piston rods in place.stage 14.cheers mick.
#33 Posted : 29 August 2016 16:25:11
Hi stage 16
The piston rods and cross heads. This just involves gluing the piston rods in, and fixing bolt to crossheads. These are not used till pack 4.so store away safely. Cheers mick.
#34 Posted : 29 August 2016 16:27:56
Hi stage 17
The rear underframe, just screwed to chassis, easy Lil job, cheers mick.
#35 Posted : 29 August 2016 16:31:47
Hi stage 18
The rear end beam and plate. Again easy screw together job.cheers mick.
#36 Posted : 29 August 2016 16:34:44
Hi stage 19
The motion frame.again easy screw together job.fits well.cheers mick.
#37 Posted : 29 August 2016 16:43:25
Hi finally for this pack stage 20.
The equalising bars.
Again all easily screwed together, and fitted well.I polished my bars up a bit as one pic shows 2 polished.the 3rd one on the right not polished yet.and the final pic of what I have so far. Sorry if putting it up in stages bores you to death.but I get lost with what's what in each pack otherwise, as quite a bit to do in each pack.really enjoying this one.cheers mick.
#38 Posted : 29 August 2016 17:37:42
Coming together nicely Mick
#39 Posted : 29 August 2016 17:46:48
Mick i do like the prepainted finish like Tony says looks damn good excellent build......... regards Phil
#40 Posted : 29 August 2016 18:23:55
Looking good Mick
The chasis looks quite long so far, I will hopefully get mine done this week time permitting as things are a bit hectic with work getting ready for an ORR visit.
9 Pages <1234>»
