Really nice build great work..........regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Joined: 11/03/2010 Posts: 234 Points: 734 Location: Whelpley Hill, Chesham
Hi Everybody, Just a small update but a surprising amount of work to fit the moulding under the nose. Now started on the tailplane. Alec alemo attached the following image(s): Built: Bluenose, Arab Dhow, HMS Bounty, Hummer H1, D51, Spitfire,E type Jaguar. In Progress: HMS Victory, , Yamaha YZR-M1
Adapt, improvise, overcome.
Very neat work, looking great. Graeme
Looks a very complex kit but your doing a great job with your build. Happy Modelling
Looking good Alec. Keep up the good work. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Some more really nice work on show Alec, will be quite the show piece when you're done
Lovely work Alec, you've done a great job with the panel under the nose... Well done..
Excellent work on the engine cowlings Alec, and nice progress altogether - she's looking good. Well done!!
Kev
Hi Everyone, A little more on the tailplane, some skinning on the rudder and tail fin, elevators are too long by about 5mm or so, will adjust when I'm absolutely sure and before I commence skinning. Alec alemo attached the following image(s): Built: Bluenose, Arab Dhow, HMS Bounty, Hummer H1, D51, Spitfire,E type Jaguar. In Progress: HMS Victory, , Yamaha YZR-M1
Joined: 13/02/2011 Posts: 2,243 Points: 6,849 Location: East Sussex
Wonderful work Alec, I can see you have mastered the metal plating I am so pleased for you, I to had extra work on the nose moulding in fact I had to reduce it down to knife edge to get it to fit it, but that what makes us modellers on a top forum. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Everyone, Feels like some good progress. Engine ready to install, hinges fitted to rudder and elevators and a dry assembly which looks ok. Still need to paint the bare edges in silver before I glue the hinges to the tailplane. There is still two small panels on the underside but they will be fitted once the tailplane is fitted to the fuselage. Alec alemo attached the following image(s): Built: Bluenose, Arab Dhow, HMS Bounty, Hummer H1, D51, Spitfire,E type Jaguar. In Progress: HMS Victory, , Yamaha YZR-M1
Hi Alec, I must say that your build is top notch, and what a great job with the tailplane, I appreciate the workmanship you have put into it. Also your engine looks the part with all the hand painting on the wires that takes some patience looking forward to your next update. Regards Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Hi Everyone, Just a small update as I have just started on the fuselage. Alec alemo attached the following image(s): Built: Bluenose, Arab Dhow, HMS Bounty, Hummer H1, D51, Spitfire,E type Jaguar. In Progress: HMS Victory, , Yamaha YZR-M1
Those panels are linking up very nicely, excellent work..... Regards Alan
Nice work Alec, you are coming up to the interesting part now you are plating the fuselage, can be a bit tricky in parts, but I can see you have the skills to complete the job. Trev. Work in progress: Tombstone (Scratch) - San Francisco 2. -The Mayflower ( scratch by plan).
Outstanding metal work Alec. You can see the amount of time and skill that has gone into this Keep up the great work
Very nice indeed Alec, your sheet metalworking skills are impressive - that tailplane looks very neat and tidy!!
Very well done.
Kev
Thanks for looking in and the generous comments. First time today I took off a panel and will have to use a spare sheet to make a new one it's the big one that goes over the fuselage just in front of the cockpit and it was just not big enough to reach both sides and wanted to twist so some modification is required. Rather than struggle today I walked away from it and will start fresh tomorrow. Well I guess that's model making for you! Alec Built: Bluenose, Arab Dhow, HMS Bounty, Hummer H1, D51, Spitfire,E type Jaguar. In Progress: HMS Victory, , Yamaha YZR-M1
Always best to walk away if things go awry Alec, you'll see things in a whole new light when you return and likely make a better job of it as a result? Very well done on your work so far.
Kev
Thanks Kev, Walking away was the right thing to do. The panel is replaced, cut from a spare sheet, the port side panels are on and so are the engine cover panels. I think it looks ok. Alec alemo attached the following image(s): Built: Bluenose, Arab Dhow, HMS Bounty, Hummer H1, D51, Spitfire,E type Jaguar. In Progress: HMS Victory, , Yamaha YZR-M1
