51 Pages «<1213141516>»
DaDokta`s Build Options
DaDokta
#261 Posted : 29 September 2016 10:44:00
Thanks guys for your encouraging comments!
Finished the port side-gallery yesterday:
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
Garth
#262 Posted : 29 September 2016 12:37:50
Hi Walter,
Inspiring work. Glad to see you back on your Victory.
Kind regards,
Garth
"Measure twice, cut once!!!"
Finished!!! HMS Victory,
Current build: Black Pearl.
Wish list: USS Constitution.
DaDokta
#263 Posted : 17 October 2016 07:02:51
I finally finished the transom and the galleries!
Comparing the model with the pics of the original ship, i must say i´m very satisfied with the results - as far as my skills go!
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
#264 Posted : 17 October 2016 07:12:40
BigGrin Very nicely done Walter lovely job on the painting Cool
#265 Posted : 17 October 2016 09:10:52
Walter
Wonderful update and all looking very good indeed.
#266 Posted : 20 October 2016 21:17:58
Hi walter.
Looking very good. look forward to seeing your progress.
IanCool BigGrin
Garth
#267 Posted : 24 October 2016 14:30:44
Hi Walter,
Nice update. Enjoyed looking at your paint job.
Kind regards,
Garth
DaDokta
#268 Posted : 25 October 2016 08:15:39
Thanks guys!
[size=8]Next up will be the gratings of the upper deck and rigging of the first cannons. But first i will have to repair most of the cannons as a whole shelf crashed onto the box in which i stored them!!!
Thanks for looking in!
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
z8000783
#269 Posted : 25 October 2016 08:19:35
Groups: Unapproved
Lovely work Walter, well done.
#270 Posted : 25 October 2016 08:28:38
BigGrin Nice work on the stern Walter Cool
DaDokta
#271 Posted : 31 October 2016 14:36:56
Thanks guys!
As announced i did some work on the gratings as well as the stairs
I will have to wait a week or so for some additional rigging parts as i will try some modifikations for more realism.
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
#272 Posted : 31 October 2016 18:02:10
Looking very nice Walter ThumpUp ThumpUp
#273 Posted : 31 October 2016 21:23:36
She's really looking great Walter Cool
#274 Posted : 31 October 2016 23:42:54
Doing a great job Walter, looking the biz that's for sure....Cool Cool Cool
Garth
#275 Posted : 01 November 2016 13:19:49
Hi Walter,
Lovely work. Especially the gratings. I like the contrasting colors.
Kind regards,
Garth
DaDokta
#276 Posted : 07 November 2016 07:32:55
I´ll make two Posts today - first i quick glimpse at the work i did while waiting for parts.
I attached all the wriggles:
Greetings,
Walter
Present builds:
On the shelf:
Completed builds:
#277 Posted : 07 November 2016 08:33:08
Hi Walter,
I must say very well done with your build so far, if it is any help I used 2mm blocks on mine for the very same reason and it worked out fine, have a look a CMB website.
Trev.
#278 Posted : 07 November 2016 08:43:34
Hi Walter.
Your build is coming along nicely. Doing a fantastic job.
The blocks can be cumbersome in there size. You can buy smaller from CMB then get a couple of foam sanding pads and eoll the blocks in between them to round them off.
As for the rope hair. Dilute wood glue is good but don't wet too much or rub it in as it looks false. I used both methods of wood glue and bees wax block. I found the wood glue the better and a lot easier to do when in place.
Chris
#279 Posted : 07 November 2016 09:26:17
magpie1832 wrote:
Hi Walter.
The blocks can be comebersome in there size. You can buy smaller from CMB then get a couple of foam sanding pads and eoll the blocks in between them to round them off.
Chris
Hi Walter
Lovely job you are doing on your build i must say. Always difficult when you get down to the very tiny details.
Depending on how many blocks you are looking to shape thats a great suggestion you have above from Chris. In addition to that cmb now stock a model shipways tool that is supposed to do the same thing with the use of a drill.
Its called block buster high speed block shaper.
http://www.cornwallmodel...talog/rigging_tools.html
#280 Posted : 07 November 2016 17:00:41
BigGrin Alan also posted this tool for beeswax application, may be of use . there is also a video of it being used.Cool
Its no longer in stock there but a search should bring some to light
http://forum.model-space...aspx?g=posts&t=16196
This page was generated in 0.164 seconds.
