Joined: 24/03/2010 Posts: 57 Points: 179 Location: bedford uk
hi all, as you can see i seem to have a problem with the fit of part 7 well the run from rib 16 to rib 13 and onto part 7. do i need to fair more off the ribs or should i be building out part 7? thanks all darren darrend attached the following image(s):
from what I can see is,a small amount of fairing on the two front ribs,then you have a bend in your planking, to gently bend round to the front.hope you understand this. Current builds: SotS, USS Consitution, San Felipe, D51 loco, HMS Surprise, RB7, Arab Dhow, Jotika HMS Victory Completed builds: HMS Pickel, Thermopylae, Mississipi river boat, Mary Rose, Cutty Sark, San Francisco II, HMS Victory x5, Titanic Lifeboat, Panart HMS Victory Launch, Hachette Titanic, Virginia Schooner, Endeavour Longboat. http://www.model-space.com/gb/
thanks Karl. will give that a go see if it helps
The planking at that point is meant to follow the line of the frames, therefore as Karl says, a small amount of fairing on the two front frames, and then slightly bend the planking to suit.
thanks tomick. i will see if i can get this right now
