8 Pages «<23456>»
USAF 70th Anniversary build 1947-2017 Options
#61 Posted : 25 January 2017 23:08:59
Nice work, that cockpit looks great.
#62 Posted : 26 January 2017 09:34:38
Looking great and nearing the end of the first, should lok an amazing display Cool
#63 Posted : 30 January 2017 13:28:36
Hi Carl.
Looking very nice. really great work on the cockpit.
Ian Cool BigGrin
#64 Posted : 31 January 2017 17:08:04
Coming along nicely CarlThumpUp
#65 Posted : 01 February 2017 16:21:06
OK the canopy has been added and the landing gear.The cockpit glass fit was not that great so I used some filler the blend it into the fuselage.
I started priming with Tamiya white surface primer.Once I have got a good covering and made sure all the seams are gone and panel lines are back I will be using testors gloss white for the top coat.
#66 Posted : 01 February 2017 16:43:24
Looking great CarlBigGrin Cool Phil
#67 Posted : 01 February 2017 17:47:24
Nice looking model.
Going to be a wonderful diplay full of colour when complete.
#68 Posted : 01 February 2017 19:20:53
I do like the stage where you add primer and its all one colour, the build starts coming to life. Nice work!BigGrin
#69 Posted : 01 February 2017 21:58:23
Another great update, coming along really nicely...Cool Cool
#70 Posted : 01 February 2017 23:00:14
Real nice paint job carl.
Looks Great.
Chris Cool
#71 Posted : 02 February 2017 15:03:58
Coming along nicely Carl Cool
#72 Posted : 13 February 2017 00:37:01
Now the T38 is going to be in the spray booth for a while getting a gloss coat I am moving on with the next kit
F84F Thunderstreak
This is a kinetic kit.I added in an Aires resin cockpit set and a correct nose piece.The kit is pretty simple.The panels lines are a bit heavy , but I will be using Tamiya spray lacquer for this one so I think once the paint is applied the lines will look less noticeable. Fit seems pretty good so far, but the parts are quite thick with pretty big sprue attachment points.
#73 Posted : 13 February 2017 08:21:29
Looks a nice kit CarlBigGrin and those resin updates will make a differenceDrool Cool it`s going to be a jet assembly lineBlink LOL regards PhilCool
#74 Posted : 13 February 2017 09:39:00
Its like watching an aircraft production line, keep up the good work, should be a fantastic end result Cool
#75 Posted : 13 February 2017 15:03:00
Nice work on the Talon, look forward to seeing more on the thunderstreak.
#76 Posted : 13 February 2017 19:09:10
BigGrin Looks a nice kit and the extra's will bring her to lifeCool
#77 Posted : 13 February 2017 19:22:23
Model 2 is a nice looking aircraft.
Hope it all goes together well for you.
#78 Posted : 13 February 2017 21:33:22
Boeing factory eat your heart out, we got a Carl!LOL Coming along nicely!BigGrin
#79 Posted : 13 February 2017 22:34:27
Nice to see everything in full flow Carl, looking great....Cool Cool .. Look forward to your next of many updates.....Cool Cool
#80 Posted : 14 February 2017 19:40:19
The resin cockpit is painted now.The instrument panel needs to be fitted and then you need to do some surgery to the fuselage sides to fit the resin cockpit.
8 Pages «<23456>»
