 Rank: Pro  Groups: Registered
Joined: 27/02/2017 Posts: 410 Points: 1,220 Location: Lancashire
Hi, Yes I'm happy with the decision, I have literally no experience what's so ever so it's as you say Geoff this build a bit to expensive to be playing around with it especially with my zero knowledge on the subject. May.
Hi, Well look what arrived this morning  my first delivery of issues 1 and 2. I wasn't actually expecting this until next week so it was a nice surprise to say the least. I know a lot of you chaps are saving the parts to build in bulk but these bite sized chunks suit me just fine so I'm building as I get them. The thing that surprised me the most was the sheer size of it, not being a modeller the 1:8 scale meant nothing to me so to actually see the full scale image in the supplement that come with the magazine was really nice As Geoff pointed out earlier, the colour is perhaps a little darker than I was expecting when compared to the adverts etc, but that suits me fine I prefer this darker shade. The instructions seem nice and clear so even I could follow them There is one thing to say though which is the screwdriver that was supplied wasn't magnetic, I don't know if that is how it's supposed to be but I had a hard time picking up those tiny screws that come with issue 1. In the end I gave up and used the screwdriver that came with the R2-D2 build instead, it was a bit big for these screws but I got there in the end. Anyway here's some pics and thanks for dropping by May. MFG attached the following image(s):
Good to see you up and running with the Jag. WTG Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Good to see you starting this one. Screwdriver (test and issue 1 so i have 2) are not magnetic but you can make them so if you have a magnet available. Just stroke the screwdriver blade across the magnet a few times and that will work. Happy building. Happy Modelling
Hi, Thank you chaps, Thanks for the tip Tony I'll give that a go May.
Joined: 20/02/2012 Posts: 83 Points: 249 Location: Midlands
Hi May, Pleased to hear you have received your first parts and you have got off to a head start. Still waiting for my parts to arrive, but there is no rush, as I have decided to start my Honda CB750 build diary, which due to my recent illness, got delayed. You can follow this on the Honda Build Diary forum, if you so wish. Only another month May,for your next parts BUILDING - HONDA CB750 - HAYNES V8 VISIBLE ENGINE
NEXT BUILD - JAGUAR E-TYPE
GEOFF
Hi, Sorry to hear that you have been "under the weather" Geoff, I hope your now on the mend. Yes it was a nice surprise to get them this morning and as you say there's just 28 more days to go until the next delivery May.
Joined: 22/02/2017 Posts: 155 Points: 474 Location: Ireland
Nice start May. Look forward to seeing it progress. Graham I was drowning my sorrows. But my sorrows they'd learned to swim.
Always great to see a new build get underway and looks like you're off to a good start.... will be following.... Regards Alan
 Nice start May Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi, Thank you chaps, Yes it was nice to get going with it, although I did have a bit of a wobble, in the official diary the logo on the oil cap is orientated differently to mine but as there is a notch on the underside so it can only go one way I'm guessing that the parts have been altered? Anyway I'm already looking forward to the next delivery but in the meantime the next instalment of R2-D2 is due soon May.
May They have changed the direction of the oil filler cap since the test pieces from last year. Hoping to get my "proper"subscription parts soon so that i can correct a couple of things that need to be changed as a result of using the old parts. Happy Modelling
Good to see parts arriving and build diarys up and running. Hope you enjoy the build
Hi, Yes it was actually your diary Tony that gave me the answer because I knew that your are using test parts so it all made sense in the end With a bit of luck your subscription delivery should be with you soon, as far as I can tell it's only the oil cap that has changed in issues 1+2 May.
Hi Thank you Davetwin It was nice to get started, I think most people are collecting parts for awhile until they get going but I couldn't resist it May.
 Rank: Super-Elite        Groups: Official Builds, Administrators, Moderator, Global Forum Support, Registered Joined: 04/06/2011 Posts: 5,886 Points: 17,810 Location: ipswich
There's a post somewhere here that says the main bonnet panel has been altered too - the fixing points/posts have been moved so the test bonnet won't be any use on the actual kit.
roymattblack wrote:There's a post somewhere here that says the main bonnet panel has been altered too - the fixing points/posts have been moved so the test bonnet won't be any use on the actual kit. Indeed there are some major fixing point changes to the bonnet with some being removed, some added and some moved. Was also advised that its had some additional paint coats to thevtest version so the colour should be a lot better than the test fersion. Happy Modelling
I've got the test parts and the new ones but I can't see any difference in the paint . I opened up both packs and the inner fixings are indeed very different.
Hi, Interesting, it makes you wonder why they changed it as the kit is said to be a exact replica of the real car so surly the fittings would match in appearance? Anyway I'm sure the changes are for the better May.
Hi, My second delivery arrived today with issues 3 & 4. The kids are at the in-laws today so I had the afternoon to my self to work through these issues Issue 3 No problems here the task was to install the horn button on the wheel - easy even for me MFG attached the following image(s):
