6 Pages «<456
The King Wanted Bling ---Sovereign Build Log Options
#101 Posted : 27 March 2017 20:13:18
Its a real trial on these larger hulls to get to the end but well done for keeping going.
You should now give yourself a pat on the back as your now getting to the stage of adding all those lovely detail bits and pieces.
Hope it all continues well for you.
#102 Posted : 27 March 2017 22:28:34
Progressing nicely Nige, looks as if you have a nice smooth surface for the next layer....Cool Cool .. Look forward to your next update....
#103 Posted : 27 March 2017 22:39:00
Looking great, soon be the second planks then will look different again.
Chris Cool
scraperjawa
#104 Posted : 28 March 2017 05:15:22
Hey Nige,
Looks like it is coming along nicely. I have put my boat aside for a bit to work on my Falcon again, but I will get back to it soon. I needed a break from the planking. Keep up the good work.
Stephen
Current Builds: HMS Sovereign of the Seas /// Lamborghini Countach /// Eaglemoss BTTF DeLorean
Nige
#105 Posted : 28 March 2017 16:59:30
Thanks guy's for looking in and all your help and encouragement. Wouldn't have got this far without you.
The next build pack will most likely arrive before Iv'e got the hull ready as I have lots of sanding ahead of me. I've given the hull a quick / light sand with 80 grit and am now starting to fill and smooth with 120 grit.
When I'm happy will finish with 240.
I'm actually dreading the thought of cutting the gun ports in my beautiful hull Blushing Still that's a long way off as some nights I just sit a stare and run my fingers over the hull.
Rgds Nige
Building: Sovereign Of The Seas Reading About Everyone Elses Builds[/b]
Enjoy Making
Nige
#106 Posted : 28 March 2017 18:10:02
Hi Nige, the cutting out of the gun ports is nothing to be concerned about and am sure you'll do a great job. Measure twice before cutting anything and take a look around to see the different methods members use, deciding for yourself the best method that suits you..... Will be following to see how you get on......Cool Cool
#107 Posted : 28 March 2017 20:34:42
Nice work with the planking, the hull looks great.
Nige
#108 Posted : 29 March 2017 02:51:09
Thanks Graeme for the thumbs up that means so much. I actually found the planking very relaxing to do.
Rgds Nige
Enjoy Making
Nige
Garth
#109 Posted : 27 May 2017 17:25:40
Hi Nige,
Good work on the hull. Planking coming along nicely.
Kind regards,
Garth
"Measure twice, cut once!!!"
Finished!!! HMS Victory,
Current build: Black Pearl.
Wish list: USS Constitution.
Nige
#110 Posted : 29 May 2017 09:33:28
Hi All - Update Time
Thanks For Looking In And All Your Comments
Work on my Sovereign has slowed a bit but I have been making progress. Iv'e cut out the gun ports and started the second planking. Even though I checked and rechecked several times a couple of the ports needed adjustment. This was nothing major just a very slight tweek so the ports all followed the flow of the second planking. Incredible really how even 0.2mm can really show up but I now have a nice gentle curve. I hope and prey this slight change doesn't come back to bite me when the later detail go's on.
To anyone considering a build of their own and perhaps a little unsure I would say go for it the quality of the supplied parts, detail to the instructions and support / helpful suggestions from members on this forum fantastic. I still can't quite believe I'm doing this and am loving every minute BigGrin BigGrin BigGrin
So some Photos: Regards Nige
Nige attached the following image(s):
Enjoy Making
Nige
#111 Posted : 29 May 2017 09:40:40
Progressing very nicely Nige, looking good....Cool Cool
DaDokta
#112 Posted : 29 May 2017 10:10:23
The second planking Looks very nice!
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
#113 Posted : 29 May 2017 10:19:44
BigGrin Very nicely done on the planking she is starting to look the biz Cool
#114 Posted : 29 May 2017 11:21:44
You are doing a great job NigeBigGrin regards PhilCool
Nige
#115 Posted : 23 January 2021 10:56:48
Hi all,
It's been a while with very little being done on my build but I have now finally been able to resume building again.
Enjoy Making
Nige
6 Pages «<456
