106 Pages «<2122232425>»
Sticky Wickett
#441 Posted : 05 April 2017 07:28:03
Another photo of the completed panelling.
Sticky Wickett
#442 Posted : 05 April 2017 07:29:57
This photo shows the panelling fixed to the U-boat [upside down].
Sticky Wickett
#443 Posted : 05 April 2017 07:33:42
This photo shows the U-boat the correct way up, panelling fixed in place. I'm very happy with the way it turned out as it carries on the theme from the brass panelling supplied with the part-works; the Engine Room to the left of the photo and the Control Room to the right of the photo.
Sticky Wickett
#444 Posted : 05 April 2017 07:35:35
Well that's it for this weeks U230 build log from 'The Dockyard'.
Thanks for looking in, have a great week and happy modelling!BigGrin
Kind Regards,
Phil W.
#445 Posted : 05 April 2017 09:34:26
Lovely work Phil and very well described....Cool Cool
#446 Posted : 05 April 2017 10:17:10
Great job Phil, looking fantastic.
#447 Posted : 05 April 2017 11:33:37
Hi Phil.
another great update. looking fantastic.Cool BigGrin Drool Ian
Sticky Wickett
#448 Posted : 05 April 2017 14:24:21
Thank you Alan. Slowly making progress.
Phil.
#449 Posted : 05 April 2017 14:38:54
Just better and better PhilDrool Drool Love can`t wait to see the colour and you starting on the interiorBigGrin regards PhilCool
Sticky Wickett
#450 Posted : 05 April 2017 16:37:07
Thanks very much Graeme.
Phil W
#451 Posted : 05 April 2017 17:26:54
More lovely work Phil, you can certainly see the love that you're putting into the build Cool
Sticky Wickett
#452 Posted : 06 April 2017 09:15:36
ian smith wrote:
Hi Phil.
Thank you Ian. More posts to follow soon.
Kind Regards,
Phil W
Sticky Wickett
#453 Posted : 06 April 2017 09:16:55
Thanks Phil. I'm itching to get some paint on her - just have to be patience and get all the rivets and weld lines fixed first.
Phil W.
Sticky Wickett
#454 Posted : 06 April 2017 09:18:25
Thank you Dave. It's a labour of love mate. More posts to follow soon.
Kind Regards,
Phil W.
Sticky Wickett
#455 Posted : 06 April 2017 09:19:45
Thank you for looking in and all the positive comments. More posts to follow soon.
Kind Regards,
Phil W.
Sticky Wickett
#456 Posted : 12 April 2017 18:36:33
Good Evening Fellow Modellers from 'The Dockyard'.
This weeks build log of my U230 U-boat will be looking at fitting out No.2 Battery Compartment and also fitting the part-works supplied, etched brass ballast tank covers.
The attached photo shows the cut-out which will represent a glimpse of No.2 Battery Compartment. The actual battery compartment runs the full length beneath the Junior Rates Mess & Galley.
The batteries fitted to the U-boats were of similar design to the ones fitted to my first submarine draft; HMS/M Opportune, an 'O'-class diesel-electric powered boat.
Both the U-boats and the 'O' class boats had two battery compartments; one forward and one aft. It's not to say that there was a massive battery but rather banks of battery cells. The dimensions of these cells on 'O' class boats and U-boats were near enough the same. That is each cell stood about 3 feet tall and 15 inches square and weighed 500Kg [1/2 tonne]! The main difference was that 'O' class boats had more cells; 128 per battery compartment, whereas the U-boats had 64 cells per battery.
The attached photo shows the cut-out of what will become No.2 Battery Compartment.
Sticky Wickett
#457 Posted : 12 April 2017 18:39:20
The first job was to add a backing sheet of 0.25mm thick plastic sheet to the planking; to aid strength and provide a suitable surface for which to add details.
This photo shows the backing sheet cut to shape.
Sticky Wickett
#458 Posted : 12 April 2017 18:40:26
This photo shows the planking being covered in PVA in readiness for fixing the backing sheet.
Sticky Wickett
#459 Posted : 12 April 2017 18:42:38
This photo shows the backing sheet about to be fitted.
Sticky Wickett
#460 Posted : 12 April 2017 18:44:15
The backing sheet, representing the inner pressure hull, fixed in place.
This page was generated in 0.186 seconds.
