106 Pages «<3031323334>»
Sticky Wickett
#621 Posted : 08 May 2017 22:25:42
delboy271155 wrote:
Nice scratch building of the vents.Love
Congrats on your "Orange" medal. Cool Cool
Thanks Derek!!BigGrin
#622 Posted : 08 May 2017 22:33:54
More great updates from you Phil, this is turning out to be a rather special build and all credit to you....Love Love... Look forward to seeing your next update...
Sticky Wickett
#623 Posted : 09 May 2017 09:20:24
Thank you very much Alan. Your comments are appreciated! More posts to follow soon.
Phil W.
DaDokta
#624 Posted : 10 May 2017 07:41:48
Hi Phil,
i`m following your build with great interest.
As you can see in my diaries i`m also building this model but am currently concentrating on my victory-build so the U-96 is on a hold.
As i see your progress from week to week - you set such a high standard with all the modifications and ideas you have!
It`s hard not to loose interest in completing this build - as i will never be able to reach such a great result!
Keep up the great work!
Greetings,
Walter
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
#625 Posted : 10 May 2017 07:54:30
BigGrin Yet more stunning work m8 loving this build Cool
Sticky Wickett
#626 Posted : 10 May 2017 09:26:34
DaDokta wrote:
Hi Phil,
Greetings,
Walter
Thank you for the kind comments Walter! Cool BigGrin Much appreciated.
Kind Regards,
Phil.
Sticky Wickett
#627 Posted : 10 May 2017 09:27:54
I'm glad you like the build log Martyn!Cool Another month and i'll be painting her up! Woop woop!BigGrin
Sticky Wickett
#628 Posted : 11 May 2017 07:35:00
Morning from 'The Dockyard'.
This weeks update on my build log of U-boat U230 will focus on fitting the inner pressure hull and t-frames [ribs] to the space that will eventually become the Senior Rates bunks, Captains Cabin, Sonar Shack, Signals Shack and Senior Rates WC.
As with a previous post when I fitted the inner pressure hull to the Junior Rates Mess and Galley I started by fixing spacers to act as supports. These were cut from 4.5mm wide by 2.5mm thick plastic strip.
The attached photo shows one of these strips cut to length being bent around a file handle to aid fitting.
Sticky Wickett
#629 Posted : 11 May 2017 07:36:41
This photo shows the start of fitting out with some of these strips.
Sticky Wickett
#630 Posted : 11 May 2017 07:39:02
This photo shows some of the strips fixed length ways to aid support of the inner hull.
Sticky Wickett
#631 Posted : 11 May 2017 07:40:31
This photo gives you an idea of the different length of strip used.
Sticky Wickett
#632 Posted : 11 May 2017 07:41:49
Smaller pieces fitted at the ends.
Sticky Wickett
#633 Posted : 11 May 2017 07:42:40
Further strengthening strips added.
Sticky Wickett
#634 Posted : 11 May 2017 07:43:45
Another view showing the gradual build up of these strengthening strips.
Sticky Wickett
#635 Posted : 11 May 2017 07:44:43
This photo shows the curved strips being fitted.
Sticky Wickett
#636 Posted : 11 May 2017 07:46:07
All strengthening strips completed.
Sticky Wickett
#637 Posted : 11 May 2017 07:50:46
The next step was to make the inner hull shell using 0.5mm plastic sheet. Careful trimming and filing was required to ensure a snug fit.
The photo shows the sheet cut to size.
Sticky Wickett
#638 Posted : 11 May 2017 07:51:27
This photo shows the inner hull shell being test fitted.
Sticky Wickett
#639 Posted : 11 May 2017 07:53:44
Once I had the inner hull shell test fitted I marked with a pencil a cut line to remove the excess.
Sticky Wickett
#640 Posted : 11 May 2017 07:54:32
This photo shows the cut line.
