106 Pages «<3132333435>»
Sticky Wickett
#641 Posted : 11 May 2017 07:58:08
The inner hull shell was then glued in place making sure that it was pushed right up against the strips as mentioned before.
I then added a lip of plastic sheet 0.5mm to the front edge giving the impression that the hull has been cut through. This lip also acts a guide for the ribs at each end to sit against.
Sticky Wickett
#642 Posted : 11 May 2017 08:07:55
This photo shows first rib fixed in place. This rib was pushed up against the inner hull to get the correct curve and as can be seen the lip provides an edge for it to butt up against.
Sticky Wickett
#643 Posted : 11 May 2017 08:09:20
Another photo of the same rib.
Sticky Wickett
#644 Posted : 11 May 2017 08:12:01
This photo shows the second rib being fitted. Using my spacers I made in a previous post when fitting out the Junior Rates Mess and Galley ensured the ribs are fitted parallel to one another.
Sticky Wickett
#645 Posted : 11 May 2017 08:13:04
Another photo of the second rib being fitted.
Sticky Wickett
#646 Posted : 11 May 2017 08:15:38
Using this technique I proceeded to fit the rest of the ribs. This photo shows the half way stage.
Sticky Wickett
#647 Posted : 11 May 2017 08:17:07
This photo shows the ribs being left slightly longer than required as it's easier to trim them to length when fitted.
Sticky Wickett
#648 Posted : 11 May 2017 08:18:13
All ribs fitted.
Sticky Wickett
#649 Posted : 11 May 2017 08:19:38
This image shows the completed ribs cut over-length prior to trimming.
Sticky Wickett
#650 Posted : 11 May 2017 08:22:55
To simulate that 'cut-through' impression of the compartment I glued smaller ribs butted to the lip I mentioned before. These were also cut to length after fitting.
Sticky Wickett
#651 Posted : 11 May 2017 08:25:02
I used a dremel to remove the excess from all of the ribs then sanded them flush. This photo shows the main ribs being sanded down.
Sticky Wickett
#652 Posted : 11 May 2017 08:26:07
This photo shows the ribs sanded flush.
Sticky Wickett
#653 Posted : 11 May 2017 08:27:51
Once the ribs were sanded flush I completed the look by sanding a bevelled edge to them so that they 'carry on theme' I applied to the Junior Rates Mess and also the Engine Room.
Sticky Wickett
#654 Posted : 11 May 2017 08:30:13
That completes the fitting of the inner pressure hull and t-frames for the Senior Rates bunks, Captains Cabin, Sonar Shack, Signals Shack and Senior Rates WC.
Sticky Wickett
#655 Posted : 11 May 2017 08:32:14
Next week I will continue with this compartment by fitting the scalloped saddle tank end profiles.
Until then, thanks for looking in, have a great weekend and happy modelling.
Kind Regards,
Phil W.BigGrin
#656 Posted : 11 May 2017 17:53:30
Another great update Phil BigGrin looking forward to the next oneDrool BigGrin regards PhilCool
Sticky Wickett
#657 Posted : 11 May 2017 23:48:30
Thanks Phil. Stay tuned for more posts next week!BigGrin
Phil W.
#658 Posted : 12 May 2017 07:13:06
Phil
Looking really good.
The details you are adding into this build are wonderful.
Sticky Wickett
#659 Posted : 12 May 2017 09:14:55
birdaj2 wrote:
Phil
Thank you very much Tony!BigGrin I'm looking forward to painting it up I must say. Another month and the paint goes on!BigGrin Cool
Sticky Wickett
#660 Posted : 18 May 2017 07:44:15
Good Morning from 'The Dockyard',
On this weeks post of my U230 U-boat build log I will be showing you how I made the scalloped and profiled saddle tank ends that sit either end of the Senior Rates Mess.
The technique I used to make them follows the same system I employed on the Junior Rates Mess / Galley in a previous post.
The overall look remains in keeping with the part-works supplied etched brass sheet for the Control Room and Engine Room.
The first job was to cut out a thin strip of 0.5mm plastic sheet and fix it to the ribs at end of the compartment. This strip represents a part of the inner pressure hull.
The attached photo shows the aft inner pressure hull strip being fixed in place.
This page was generated in 0.210 seconds.
