issue 64 steering problem Options
deano2310
#1 Posted : 10 May 2017 19:19:35
Rank: Beginner Level 1
Having trouble with the steering pinion engaging with the steering rack. Even with the pinion gear box that goes over it the steering wheel when turning does not engage the steering rack could anyone please help me
Dean
Current Builds: Shelby Mustang, Harley Davidson, Spitfire and Delorean
Finished: McLaren MP4-23, Aston Martin DB5
#2 Posted : 10 May 2017 19:35:11
Hi Dean, BigGrin
Could you post some pics of your problem, it will make it easier to advise what you need to do.
deano2310
#3 Posted : 10 May 2017 19:53:48
thanks for your time :)
Dean
deano2310
#4 Posted : 10 May 2017 19:56:01
see how it sits just above even with the black pinion gear box sitting in the chassis it still sits above the rack
Dean
figuerres
#5 Posted : 10 May 2017 20:11:50
yeah...
i have not got to this yet but something must not be alighned right...
or not tight ? the gears have to mesh for it to work as i am sure we all see...
i would look at how the parts are attched and see if something is missing, not tight up or bent slightly ??
only1ianuk
#6 Posted : 10 May 2017 23:27:09
I've got exactly the same problem. Took it apart and reassembled but get the same problem
#7 Posted : 11 May 2017 06:52:51
Hi Dean
Looking at your photos it looks like there is a problem with the way you have the steering box and steering rack assembled. The rack should be on the other side of the box.
Can you post a picture of underneath showing the whole steering rack assembly as I suspect this isnt quite right
Here are a couple of quick pictures I took this morning on the way out the door to work.
davetwin attached the following image(s):
deano2310
#8 Posted : 11 May 2017 07:57:22
Will try this tonight when I get home from work many thanks
Dean
70 Coupe
#9 Posted : 11 May 2017 16:08:23
I've had the same issue, but since the front wheels are still poseable, (I won't be pushing it up and down the carpet going brum brum and reversing into shoebox garages, ) it's no big deal BigGrin
Hope that doesn't sound sarcastic, it's not meant to be Blushing
#10 Posted : 11 May 2017 18:14:35
Let me know how you get on. If you need to refer back to the instructions to check anything you'll want to look at
Issue 39 would be worth double checking all the track rods are assembled correctly
Issue 41 covers attaching the steering rack to the chassis. The rack geering teeth should fit almost touching the chassis, the lip of the steering box should hold the rack right up to the chassis. In you picture the rack is on the wrong side of the lip and there is a massive gap between the geering teeth of the rack and the chassis
lotus79
#11 Posted : 19 May 2017 12:52:07
Hi with regards to the steering problem,i have the same problem on close inspection i find that the pinion on the end of the steering rod does not appear to go forward enough, it seems to hit the cross member and it wont drop onto the steering gear, i am not sure if this looks to be the problem to any one else, info would be good. Many thanks Mel
lotus79
#12 Posted : 19 May 2017 13:15:24
hi just sorted my problem with the steering i had the rack under the bracket that holds it up so now works perfectly so sorted thanks for the pics thats where i noticed it Cursing Cursing
#13 Posted : 19 May 2017 13:25:40
Glad you got your issue sorted.BigGrin
#14 Posted : 19 May 2017 15:50:41
That appears to the be the same issue that deano had by lookng at his photos.
Glad you got it sorted and that it was something simple, these things happen Cool
Guest (6)
This page was generated in 0.087 seconds.
