106 Pages «<4041424344>»
Sticky Wickett
#821 Posted : 15 June 2017 17:59:19
The brass bulkhead door being checked for fit.
Sticky Wickett
#822 Posted : 15 June 2017 18:00:38
In this photo you can see the difference in size between my bulkhead on the left and the AMP on the right.
Sticky Wickett
#823 Posted : 15 June 2017 18:12:28
My plan was not to remove all the details from the AMP and transfer them across to the new one as I will add the small details later on in the year. This is so I can get all the compartments ready for paint without having to negotiate the spray gun around pipes, pumps and valves.
There were however, three eyelets which, on the real thing, were welded to the bulkhead and used to fix chains and block and tackles too when lowering torpedoes through the forward loading hatch. I opted to fix these to the bulkhead as painting around them won't be so problematic.
I decided to make my own based on the measurements I collated from the AMP.
The eyelets were made from 3mm x 1mm plastic strip. I drilled a 1.6mm hole through the strip to form the eyelet itself. I filed the curve around one end and cut the other end to give me the correct length. I made three in total.
The attached photo shows the first eyelet drilled and filed prior to cutting compared to the AMP part.
Sticky Wickett
#824 Posted : 15 June 2017 18:13:29
A close up of the eyelet prior to cutting.
Sticky Wickett
#825 Posted : 15 June 2017 18:14:06
Cut to length.
Sticky Wickett
#826 Posted : 15 June 2017 18:16:44
All three eyelets completed.
Sticky Wickett
#827 Posted : 15 June 2017 18:34:27
After transferring the measurements for the eyelet locations over to the new bulkhead I glued all three in their respective places.
The attached photo shows the eyelets fixed in place.
Sticky Wickett
#828 Posted : 15 June 2017 18:35:35
From another angle showing the eyelets attached.
Sticky Wickett
#829 Posted : 15 June 2017 18:36:58
This photo shows the different locations of the eyelets that were used for lowering torpedoes down into the U-boat.
Sticky Wickett
#830 Posted : 15 June 2017 18:42:10
The next job was to make the bulkhead door surround to mimic what was on the AMP. For this used 1.0mm square plastic strip. Having marked out the start and finish of the surround on the bulkhead, i bent the strip around a 5.0mm drill bit to form the curved corners. Superglue was applied to the edge to fix in place.
The attached photo shows the strip being compared to the AMP bulkhead.
Sticky Wickett
#831 Posted : 15 June 2017 18:43:16
Surround fitted and compared next to the AMP.
Sticky Wickett
#832 Posted : 15 June 2017 18:44:19
A close up of the new bulkhead.
Sticky Wickett
#833 Posted : 15 June 2017 18:45:15
Looking from the left.
Sticky Wickett
#834 Posted : 15 June 2017 18:48:06
Looking from the right.
Sticky Wickett
#835 Posted : 15 June 2017 18:49:26
I also fitted a smaller, straight piece under the bulkhead door opening.
Sticky Wickett
#836 Posted : 15 June 2017 18:50:39
The completed aft bulkhead looking side on.
Sticky Wickett
#837 Posted : 15 June 2017 18:51:45
A close up of the completed aft bulkhead.
Sticky Wickett
#838 Posted : 15 June 2017 18:53:22
The torpedo compartment aft bulkhead completed and fitted in place.
Sticky Wickett
#839 Posted : 15 June 2017 18:56:10
A distance shot of the aft bulkhead.
Sticky Wickett
#840 Posted : 15 June 2017 19:01:26
Well that concludes this weeks update. Stayed tuned for next week when i'll be finishing the torpedo compartment by fitting the second inner shell, adding all the t-frames and the torpedo loading hatch.
Thanks for looking in, have a great weekend and happy modelling!BigGrin
Phil W.
