Rank: Administration  Groups: Administrator, Administrators, Forum Support Team, Global Forum Support, Global Forum Support Team, Moderator, Official Builds Joined: 24/08/2009 Posts: 1,943 Points: 5,841 Location: UK
Catapult build, of which there are two (both are identical), they will be later installed onto their respective bases either side of the aircraft deck already in place. Tomick attached the following image(s):
Build of the crane and mast. Care needs to be taken with the alignment of the PE framework, the simple jib hook is formed from the wire which is also used to secure the jib to the platform. Tomick attached the following image(s):
Gun barrels and blast bags. Tomick attached the following image(s):
Yamato command tower radar & antenna. The mesh is easiest cut with scissors, the wood block is only used as a shape form for the mesh. The folding of the PE radar sections need careful thought and method, its a very delicate item until its rectangular internal mesh is added. The antenna parts are formed from the supplied brass wire, and the top of the command post is drilled for the fit of the support legs. Tomick attached the following image(s):
Tower ladder bases & ladders added. Tomick attached the following image(s):
Bridge detail parts, signal lamps & macgine guns added Tomick attached the following image(s):
Gun barrels installed into the main gun turrets Tomick attached the following image(s):
Four machine guns added Tomick attached the following image(s):
Secondary gun barrels added and antenna. The antenna solder joints need to be carefully cleaned up and the antenna set into drilled holes in the turret top. Tomick attached the following image(s):
