106 Pages «<4647484950>»
Sticky Wickett
#941 Posted : 12 July 2017 16:10:59
Another view of the new section. Not a bad job at all!BigGrin
Sticky Wickett
#942 Posted : 12 July 2017 16:18:22
Once that was done I test fitted the deck and also the torpedo tubes to check for clearance. All looking good! BigGrin The Torpedo Compartment is now ready for undercoating!Cool
All the compartments are now paint ready but before I can start on that there are some other smaller jobs to be done externally on the hull.
Starting from the bow and working aft I will over the next two weeks add any part-works supplied parts, carry out running repairs and scratch build any items in readiness for adding the weld lines and rivets.
First job was to carry out some running repairs at the bow section. Three different sections of brass strip rivets had partially lifted away due to handling and required a spot of glue to remake the bond.
The attached photo shows one of the brass strip rivets.
Sticky Wickett
#943 Posted : 12 July 2017 16:30:49
Once I was happy the rivet strips were all laying flat I then proceeded to look at the part-works supplied brass strips that run along the port and starboard sides near the bow.
The attached photo shows one of the brass strips fitted to the starboard side. It took a few attempts as there is twist to the hull and the strip wouldn't adhere as it flexed too much. My method was to hold it in place with one hand and run a bead of glue along it's edges in small sections ensuring it adhered properly all the way along. It might still add 1.0mm aluminium pins along it's length at some point to make sure it doesn't come away. That will be a job for later.
Sticky Wickett
#944 Posted : 12 July 2017 16:32:36
Another view of the same brass strip. I had to file a contour on the one end to match the profile of the hull.
Sticky Wickett
#945 Posted : 12 July 2017 16:34:08
The next brass strip fitted, shaped at one end to align with the anchor well.
Sticky Wickett
#946 Posted : 12 July 2017 16:35:26
Another view of the brass strips so far fitted.
Sticky Wickett
#947 Posted : 12 July 2017 16:36:52
The final piece fitted to the starboard side of the bow.
Sticky Wickett
#948 Posted : 12 July 2017 16:38:43
The same technique was applied to the port side. The attached photo shows all brass strips fitted.
Sticky Wickett
#949 Posted : 12 July 2017 16:39:48
A close up of the bow, port side.
Sticky Wickett
#950 Posted : 12 July 2017 16:41:02
Port side brass strips complete.
Sticky Wickett
#951 Posted : 12 July 2017 16:42:36
Well that's it for this weeks update, more posts to follow next Thursday.
Thanks for looking in, have a great weekend and happy modelling.BigGrin
Phil W.
#952 Posted : 12 July 2017 18:21:19
Hi Phil you`re updates are greatBigGrin love all the work you`ve put in so far Drool Drool looking forward to the paintDrool BigGrin regards PhilCool
#953 Posted : 12 July 2017 19:24:29
Another excellent update Phil, really loving all of the extra scratchbuilt parts that you are adding to this model and it will certainly pay you back with big dividends in the way the completed model looks - very well done, looking forward to next Thursday already!! Cool Cool ThumpUp
#954 Posted : 12 July 2017 20:34:34
Another great update Phil. Looking really good.
Sticky Wickett
#955 Posted : 12 July 2017 21:04:02
Thanks for your kind comments Phil!Cool Bring on the paint!BigGrin
Sticky Wickett
#956 Posted : 12 July 2017 21:05:41
Hi Kev, i'm glad you enjoy reading the updates.Cool Stay tuned next week for another post on my U230 U-boat build.BigGrin
Sticky Wickett
#957 Posted : 12 July 2017 21:07:56
Thank you very Graeme.Cool I'm glad you like the updates.BigGrin
Phil W.
#958 Posted : 13 July 2017 07:59:51
Excellent work as usual Phil.
#959 Posted : 13 July 2017 15:52:21
Another fantastic and enjoyable update Phil.
All the extra work and detailing is really going to pay off, cant wait to see it under some point Drool Drool
#960 Posted : 13 July 2017 17:08:24
Just collected the final issue of this but no idea when I will get around to it. When I do I will be using your build for guidance, nice work so far BigGrin
