2 Pages 12>
Body work yellowing Options
Steve279021
#1 Posted : 15 July 2017 19:24:00
I decided to get my mp4/4 out and have found that the nose has yellowed, possibly from exposure to the sun. Has anyone else had this?
https://flic.kr/p/WyqdhV
Dodge charger build complete
Senna lotus 97t complete
#2 Posted : 15 July 2017 20:19:44
I have heard of yellowing models on other forums, its normally due to the varnish that is used, with the varnish itself actually yellowing.
#3 Posted : 15 July 2017 20:24:40
Steve279021
#4 Posted : 15 July 2017 21:10:04
stevie_o wrote:
It's generally not a good idea to display any model in direct sunlight. You say "I decided to get my mp4/4 out" so im guessing that sunlight is not the problem here?
When i say get it out i have my mp4/23 which i alternate with as i have 1 display case. So i was getting out the mp4/4 for its stint in the display case. But i didn't notice it when i put it away last time but that's not to say that it wasn't like it.
Is there anything i can do about it?
#5 Posted : 15 July 2017 21:48:25
Hi Steve
Looks like a respray job as once the paint/plastic has discolored its hard to get back, think of all those white double glazing frames that go yellow and grey overtime due to burn from the elements and sunlight, you could use the Tamiya rattle can TS-26 or Zero paints do an equivalent, link below:
https://www.emodels.co.u...6-pure-white-85026.html
http://www.hiroboy.com/P...60ml--product--940.html
If you use the zero paints then you will need there diamond coat take a look at my cobra build to see the deep shine achievable:
http://www.hiroboy.com/D...ml--product--10301.html
http://forum.model-space...spx?g=posts&t=22011
The front decals are still available at autograph:
https://shop.autographmo...en-MP4-4-1-8-front-wing
Before you do anything double check that its only the front wing that needs a respray and do a test piece to see if the paint matches the rest of the body it may be a case of a complete respray of all the body parts to get a good colour match. If a complete respray is needed all the decals are still available at Autograph but the cost of the decals and the respray will be expensive.
Steve279021
#6 Posted : 16 July 2017 07:56:24
As its just the front wing that appears to have suffered i may try a respray of just the front wing. Think I'll get the tamiya paint. Regarding the decals i bought the nose decals last time and only used the marlboro one so i still have the rest. Do you think it'll be possible to remove the marlboro one from my wing and reuse it to save me buying a new set of decals?
Would i have to rub it down before i paint? If so what grade of paper should i use? Also would i have to remove the end plates?
#7 Posted : 16 July 2017 08:54:31
You will need to take the shine and the decals off the body and I dont think you will save any, use a fine wet and dry or micromesh to do this. Disassemble as much as you can to make the respray as easy as possible. After you get a good surface undercoat with your prefered brand and then respray.
If you have limited spraying experience I would not attempt doing this but get someone who has the experience to do it for you. To get a good finish a lot of rubbing down of the undercoat will be needed.
Steve279021
#8 Posted : 16 July 2017 09:50:50
I thought as much about the decals, don't know why i posted about it tbh!
I have very limited painting experience like you say but the way i look at it i have little to lose as it looks terrible now, worse then it does in the pic! And if i do make a complete balls of it then there is the option of buying another pack 1 for the front wing and nose.
If i use the tamiya paint will i need a lacquer on top and if so what is the best one to get?
#9 Posted : 16 July 2017 10:17:08
Any good clear coat should do but again do test pieces to see if it matches the rest of the bodywork
Steve279021
#10 Posted : 16 July 2017 10:21:46
So is that tamiya paint a good match as i will only be painting the nose?
#11 Posted : 16 July 2017 10:26:05
Tamiya TS-26 is the closest you will get to being the correct colour hopefully it will colour match the rest of the bodywork.
Steve279021
#12 Posted : 16 July 2017 11:13:22
Thanks for your help. First i have the task of removing the tiny screws to remove the body hopefully without chewing the heads up!
Steve279021
#13 Posted : 16 July 2017 12:03:52
Well it came off ok.
https://flic.kr/p/Vv4QpW
Steve279021
#14 Posted : 16 July 2017 12:06:02
And all came apart ok too. The left endplate is ok which was the one which was facing the wall so not in the sunlight.
https://flic.kr/p/WweyQd
#15 Posted : 16 July 2017 18:38:26
BigGrin Sweet, there is the option of buying issue one to replace the parts aswelCool
Steve279021
#16 Posted : 17 July 2017 08:13:17
I thought of that but then realised that i need a few other issues too as the flaps, end plates, lower nose and end plate skids come in separate issues.
Steve279021
#17 Posted : 29 July 2017 15:24:59
Finally got round to getting the parts painted and have to say I'm quite impressed with my first attempt at painting.
https://flic.kr/p/WXPzHN
As i said the left end plate didn't need doing so still has the decals on although i did have to paint the upper edge but masked the rest of it out.
Steve279021
#18 Posted : 29 July 2017 15:28:07
This is it back together.
https://flic.kr/p/X9VvbC
#19 Posted : 29 July 2017 16:52:01
Looks like you've done a great job on the re-paint.... well done....Drool Drool
Steve279021
#20 Posted : 29 July 2017 17:36:42
Thanks. Had to paint the front white triangle on the front piece of body so that it matched the painted nose.
https://flic.kr/p/X1VZYR
2 Pages 12>
This page was generated in 0.127 seconds.
