11 Pages <1234>»
Daffy's L'HERMIONE La Fayette Options
#21 Posted : 06 August 2017 18:27:49
Great start to what looks to be a great looking kit.
Good luck with the build Cool
daffy09
#22 Posted : 06 August 2017 19:29:35
Hi again, here's another update on the build.
STAGE 02
This one is all about building the lower deck and fixing it in place.
To start, the 2 halves were cut from the parts board, given the once-over with a sanding block to smooth off any burrs, and finding the veneer strips to line those parts with. The veneer, 0.5mm x 4mm is applied strip by strip starting at the straight edge where the 2 halves join and working outwards until each half was completely covered.
The 2 parts were left to dry then using a new scalpel blade the excess veneer was trimmed away and the edges smoothed down with a miniature diamond file and sand paper. The surface of the veneer then needed smoothing off, for this job I chose to use various grades of 'Micro Mesh' starting at 1500 and working down to 4000.
Once I was happy with the surface, I followed the instructions and used an automatic pencil to draw the lines of the planks, measured out 34mm along each plank ( which the instructions say is the correct length ), and used the pencil again to spot in the planking nails.
Finally, the 2 parts were given a coat of varnish, (I chose to use light oak as I already had some), left them to dry, and after a dry test fitting glued them in place on the frames. They fitted the first time and needed no adjustments for correct fit.
That completed stage 02 of the build.
Thanks for looking in.
More to follow soon.
Happy building
David
daffy09 attached the following image(s):
#23 Posted : 06 August 2017 22:39:16
Hi David,
Great to see you up and running with this one and looks like you're off to a great start....Cool Cool .. She is a lovely kit and am sure you'll thoroughly enjoy putting her together and I'll be following all the way..... Good luck with her....Cool Cool
daffy09
#24 Posted : 07 August 2017 00:41:11
Thanks Alan,
and you are right, I am enjoying this one, it's going to be a good build. I shall probably be seeking your advice at one point or another during the course of the build and will carry on following you on this one.
Happy building
David
daffy09
#25 Posted : 07 August 2017 00:57:44
Another update, thanks for the kind comments and let's begin.
STAGE 03 (part 1)
Welcome back. Stage 03 is split into 3 sections in the instructions, but I think I can narrow that down to 2
The 1st part is all about adding strengtheners to the hull by first of all adding another bulkhead to frame #6 followed by glueing 2 stiffeners into the bow section between frames #3,#4 and #5 after first test fitting them and finding they needed a gentle bend in them so out came the bending pliers and several crimps later the bend was sufficient to glue them in place.
2 more stiffeners were glued into place either side of the bow and a further 2 more stiffeners fitted between frames #9,#10,#11 and #12.
Work then continued on the stern by adding 3 horizontal sections one above the other.
That finishes off stage 02 part 1.
Part 2 will follow on tomorrow.
Hope you are liking the build so far, thanks for looking in and keep the comments coming,
Happy building
David
#26 Posted : 07 August 2017 08:26:05
daffy09 wrote:
Thanks Alan,
Happy building
David
Another very nice updated David, looking good....Cool Cool .. Will be happy to assist if ever needed, just ask.... Will be back on mine very soon....
#27 Posted : 07 August 2017 09:07:27
Hi David, great start to what looks a great build. Although I've never built anything like this, I watch and learn. BigGrin
daffy09
#28 Posted : 07 August 2017 13:03:02
Hi
@Gandale
Thanks Alan, I'll look forward to seeing your build as it progresses and thanks for the offer of help, I'll probably need it! (LOL)
Happy building
David
daffy09
#29 Posted : 07 August 2017 13:09:59
Hi
@Markwarren
Thanks for looking in on this build Mark, and for the comment (you're welcome anytime). You should try a sailing ship at some point - if that's where your interest lies (I know some of us prefer planes to ships) - they can give another dimension to our modelling skills.
Hope you look in again soon.
Happy building
David
#30 Posted : 07 August 2017 13:54:41
Great start DavidBigGrin the quality can be seen in this kit alreadyDrool also love the deckDrool regards PhilCool
Garth
#31 Posted : 07 August 2017 14:00:08
Hi David,
You have made a great start. Good luck with your build.
Kind regards,
Garth
"Measure twice, cut once!!!"
Finished!!! HMS Victory,
Current build: Black Pearl.
Wish list: USS Constitution.
Sticky Wickett
#32 Posted : 07 August 2017 14:41:55
Hi David, will be following with interest.Cool
Phil W.
daffy09
#33 Posted : 07 August 2017 14:53:32
@Tigerace
Hi Phil, Thaanks for your kind words of encouragement. Glad to have you along for the duration.
Happy building
David
daffy09
#34 Posted : 07 August 2017 14:55:06
@ Garth
Thanks for your comments and welcome aboard
Happy building
David
daffy09
#35 Posted : 07 August 2017 14:59:42
@Stcky Wickett
Hi Phil W, Glad you could look in and thanks for the kind words. Your U-boat build is coming along fantastically now and all that extra detail you're putting in will make for a truly unique build. Although I haven't been posting on your diary very often, I look in every time you post an update and sit back and admire your skill and patience.
Happy building
David
daffy09
#36 Posted : 07 August 2017 15:13:03
MICRO SHAPERS
Hi everyone
The 'Micro shapers' that I ordered from AL arrived in today's post and I'm very pleased with them. They are made from stainless steel which made them not the easiest things to cut from the sprues but the quality is top notch. Each of the tools has a varying number shapes between 12 and 16 for different sizes of plank, and will need to be used in several places on the 'L'Hermione La Fayette' build.
Here's a few images of each of the tools so you can get an idea of the variety of shapes that can be acheived.
Happy building
David
#37 Posted : 07 August 2017 18:17:48
BigGrin Nice progress and those tools look the bizzCool
daffy09
#38 Posted : 07 August 2017 22:23:50
New update,
Thanks to all who have posted their kind words here. Keep them coming.
STAGE 3 (PART 2)
Hi again,
According to the instructions for this build, section 3:1,3:2 and 3:3 are all about fitting other smaller parts onto the 3 horizontal transom pieces in order to give it more shape and to further strengthen it.
Part 3:3 sees the fitting of 2 stiffening pieces under the transom on either side of the keel.
I don't really know how to describe the process without boring you all so I'll let the following images do the talking.
That concludes stage 3.
The next update - stage 4 - is the job we all either love or hate - fairing the hull.
So we'll catch up with that soon.
Happy building
David
#39 Posted : 07 August 2017 22:44:51
Wow, Blink Blink
Only two days in and this is really getting along.
Looks great. Cool Cool Cool
Keep up the good work and I`ll try and keep up with your diary. Laugh
Looking forward to the next update.
Happy building
#40 Posted : 07 August 2017 23:45:09
Hi David, looks like you're making some great progress, looking good....
Difficult to tell from your pics and perhaps you haven't glued this but, the top horizontal former attached to part 29 shouldn't be glued to the side of the hull, it needs to be left free as you have to fit a plank in between the former and the hull when you come to the planking stage.... Have a look at my post number 27 and pic 54 of the instructions and you'll see what I mean.....
http://forum.model-space...sts&t=22632&p=2
Look forward to seeing your next update...
Guest (11)
11 Pages <1234>»
This page was generated in 0.337 seconds.
