11 Pages «<23456>»
Daffy's L'HERMIONE La Fayette Options
daffy09
#61 Posted : 10 August 2017 15:42:19
@Magpie
Hi Chris and thank you. Work is slowing down a bit now with the planks being laid one at a time and allowing plenty of drying time in between, but at least this build is going quite smoothly with no major problems yet.
Happy building
David
#62 Posted : 10 August 2017 22:49:36
daffy09 wrote:
Hi Gandale,
Thanks for the advice Alan, although I did meet a small problem in the midships area around frames #8 and #9 when laying the 2nd row of planks due to the bulge (tumblehome I think it was called on the Victory)on the frames and it necessitated chamfering the lower side of the plank somewhat and even then it didn't seem to lay right. I guess that will be sorted out with the sanding and filling when the hull is finished.
I'll probably follow the build instructions for the lower planking as I'm not too experienced at this and I shall be painting her (this will be a first as well) anyway so provided everything is smoothed out satisfactorily, it hopefully will not be a problem.
Happy building
David
Hi David, happy to help as always.... You'll find you will need to chamfer quite a number of planks in order to achieve the curvature and especially at the top of the bow.... As you are painting the hull (as I will be doing) then planking as per the instructions should be fine but will require quite a bit of sanding..... Great work to date, look forward to your next update....Cool Cool
daffy09
#63 Posted : 12 August 2017 13:25:34
Hi friends, her's another update on the L'HERMIONE build.
STAGE 5 (part 2)
After a painstaking few days, I have finally finished the upper hull planking and I'm now ready to remove the main deck (which was temporarily placed to help with the planking) and smooth it off. I appear to have gained an extra row of planks when comparing my model to the pictures in the instructions but I guess when sanded down to the heights indicated in the instructions things will work out - at least I hope they willConfused
The photos show the flow of progress through this stage - warts and all!
More to follow
Thanks for looking in and for the comments.
Happy building
David
daffy09 attached the following image(s):
#64 Posted : 12 August 2017 15:08:06
Looking great there DavidBigGrin nice workThumpUp regards PhilCool
daffy09
#65 Posted : 12 August 2017 15:42:42
@Tigerace
Thanks Phil, just finished sanding down the tops of the planks: now it looks more like the instruction photos. Going to spend the afternoon shaping and sanding down the outside of the planks in readiness for working on the gun ports. That should be interesting but at least there's only 15 each side, unlike the 100 or so on the Victory LOL
Happy building
David
#66 Posted : 12 August 2017 16:24:29
BigGrin Looking good David very nicely done on the planking Cool
daffy09
#67 Posted : 12 August 2017 16:37:04
@MartynIngram
Thanks Martyn but we'll have to wait and see how the planking turns out alright. I'm not too happy with it all the 'lumps and bumps' at the moment but it should be satisfactory when the sanding is finished.
Happy building
David
#68 Posted : 12 August 2017 18:53:40
Well done David, progressing very nicely...Cool Cool .. You found the same as I did, lots of bumps and humps and you'll have lots more appearing yet with the lower hull... Still, as you say everything should work out ok when everything is finally sanded, its amazing how different these models looks when the sanding phase is done.....Cool Cool .. Look forward to your next update....
#69 Posted : 12 August 2017 19:44:07
BigGrin Looking good, dont worry too much about the lumps and bumps they will all sand out and leave it looking just how you want it to lookCool
#70 Posted : 12 August 2017 20:22:51
Making great progress on her, I quite like the planking stage on ships BigGrin
daffy09
#71 Posted : 12 August 2017 21:39:20
@Spal
The planking isn't too bad really. It's all the sanding afterwards that takes the time especially when I've left the glue to set where it squeezed out of the joints without wiping it off beforehand. It's amazing how it seems to go harder than the wood I'm trying to sand.Mellow
Happy building
David
daffy09
#72 Posted : 12 August 2017 21:44:51
@ARPURCHASE
@GANDALE
Thanks guys, I've spent most of the afternoon on one side of her and most of the lumps and bumps have disappeared just like you said they would. But I've made harder work for myself by not wiping the glue off where it's squeezed out of the joints. It's gone really hard now and I've really got a sweat on today trying to get rid of them. Lesson learnt.
Happy building
David
#73 Posted : 12 August 2017 23:17:18
Your progressing well David.
Cool Cool Cool Cool
Those little issues will be sorted and the the things you`ve learnt will stop you doing the same again.
I see this being a very neat build when complete and I wish you all the best in the times to come.
Will be following with interest. Drool
daffy09
#74 Posted : 12 August 2017 23:38:39
@Delboy
Thanks Derek, I do hope I can do it justice, it's all a learning curve for me. All I can do is follow the instructions and get help here if required.
I've definitely learned to wipe excessive glue off the planks as I lay themBlushing . I dare say I'll learn lots more in this build.
Happy building
David
daffy09
#75 Posted : 13 August 2017 20:15:52
Welcome back to the L'HERMIONE build
STAGE 06
Just a quick update today as stage 6 is solely concerned with shaping the tops of the upper planks to conform with the levels of the tops of the exposed frames. I used my davids plane to get most of the surplus wood off and then used a sanding stick to finish off and achieve the correct profile - at the stern, there is a gentle upward slope from around frame #10 up to the transom - finishing level with the top of part #28 of the transom assembly.
I've already finished sanding one side of the hull plnking but more of that in the next update.
Thanks so much for the great comments and for taking the time to look in.
Happy building
David
#76 Posted : 13 August 2017 20:23:48
BigGrin Looking good David, smooth as silk Cool
#77 Posted : 13 August 2017 21:19:15
BigGrin The sows ear turns into a swan,looking great after the tidy up nice workCool
#78 Posted : 13 August 2017 21:27:50
Nice work, looing good.
daffy09
#79 Posted : 13 August 2017 23:41:35
@MartynIngram
@Arpurchase
@Pemberg
Thanks guys for the appreciative words. I'm quietly pleased with the outcome of the sanding, just hope the other side turns out as good, mind you, there's going to be lots of filling to do later.
Happy building
David
#80 Posted : 14 August 2017 13:20:42
Looks marvelous so far David BigGrin great updateBigGrin regards PhilCool
Guest (10)
11 Pages «<23456>»
This page was generated in 0.232 seconds.
