106 Pages «<5657585960>»
Sticky Wickett
#1141 Posted : 21 August 2017 08:59:12
ian smith wrote:
Hi Phil.
Great attention to detail with your rivets. must have a great deal of patience to do them all.
Ian Cool Cool BigGrin
Hi Ian, yes it does require a bit of patience, especially when you accidentally rub them off my mistake when turning the boat around!Blushing LOL
Thanks for looking in.Cool
Phil.
DaDokta
#1142 Posted : 21 August 2017 09:16:31
Your rivets are breathtaking! Fantastic!
May i ask where you get all the information from regarding the details on the real ship?
Greetings,
Walter
Present builds:
Revell B-24D Liberator 1:48
On the shelf:
Completed builds:
#1143 Posted : 21 August 2017 10:15:40
The riveting looks to be painstaking work but its certainly coming along nicely Drool Drool
Sticky Wickett
#1144 Posted : 21 August 2017 10:58:40
Hi Walter,
I have acquired lots of information during the past 3 years from various sources but the main 'go to' for me are articles written by Dougie Martindale of AMP [Accurate Model Parts].
He has written extensively about all aspects of Type VIIC U-boats coupled with lots of pictures.
Any questions let me know. Thanks for looking in!Cool
Phil W.
Sticky Wickett
#1145 Posted : 21 August 2017 11:01:38
Hi Dave, thanks for looking in mate!Cool Yes, it's a bit of a slow job but thankfully not every inch of the U-boat has rivets. Just the bow and stern have concentrated areas of riveting. When these areas are complete the project should start to gather a little momentum.
Phil W.BigGrin
Sticky Wickett
#1146 Posted : 24 August 2017 22:30:48
Good Evening from 'The Dockyard'.
This weeks update of my U230 U-boat build continues with riveting the bow section and marking out in pencil further rivet lines and weld lines.
The attached photo shows the horizontal rivet pattern around the torpedo bow caps.
Sticky Wickett
#1147 Posted : 24 August 2017 22:34:17
Starboard rivet pattern from another angle. I also refilled one of the free flood holes as it slightly too large. It's yet to be dressed and cleaned up.
Sticky Wickett
#1148 Posted : 24 August 2017 22:35:07
This photo shows the riveting on both sides.
Sticky Wickett
#1149 Posted : 24 August 2017 22:36:10
Continuing the rivets along the starboard side.
Sticky Wickett
#1150 Posted : 24 August 2017 22:37:29
Overhead photo of the lower, starboard bow.
Sticky Wickett
#1151 Posted : 24 August 2017 22:39:48
This photo shows a further section marked in pencil, providing guide lines for the rivet strips.
Sticky Wickett
#1152 Posted : 24 August 2017 22:40:48
Port side section marked out in the same way.
Sticky Wickett
#1153 Posted : 24 August 2017 22:42:11
The attached photo shows an overhead shot where you can see both sides showing the marking out for the rivet lines.
Sticky Wickett
#1154 Posted : 24 August 2017 22:43:52
This photo shows one of the horizontal weld lines being marked out. The same procedure was carried out on the port side.
Sticky Wickett
#1155 Posted : 24 August 2017 22:45:08
This photo shows the weld lines marked out and further guide lines for the rivet strips being drawn.
Sticky Wickett
#1156 Posted : 24 August 2017 22:46:20
Port weld lines and rivet strip guide lines marked out.
Sticky Wickett
#1157 Posted : 24 August 2017 22:47:23
Starboard rivet and weld lines marked out.
Sticky Wickett
#1158 Posted : 24 August 2017 22:48:21
Overhead photo showing the marking out.
Sticky Wickett
#1159 Posted : 24 August 2017 22:49:23
Looking aft along the keel.
Sticky Wickett
#1160 Posted : 24 August 2017 22:57:57
That's it for this week's update. I've got to say the marking out took longer than anticipated but it makes it so much easier when applying the rivet strips.Cool
Next week i'll be completing the bow section rivet and weld lines; from then on the casing is riveted while the saddle tanks are left as whole sections, broken up by further weld lines. The last section is the stern and this receives extensive treatment similar to the bow.Blink All this will take another 3-4 weeks as i'm on holiday the week after next!!BigGrin
Thanks for looking in, have a great Bank Holiday weekend and happy modelling!
Phil W.
