11 Pages «<678910>»
Daffy's L'HERMIONE La Fayette Options
#141 Posted : 11 September 2017 08:36:20
BigGrin Looking very nice David a good base for the second planking Cool
daffy09
#142 Posted : 11 September 2017 09:18:40
Hi Martyn
Oh! How I wish!! Unfortunately, this one's only a single planking job so plenty of filling and sanding will be the order of the day here my friend. As I'm going to be painting her the next stage or two will be critical to the finish so it may take a while to get there. In the mean time, on with the face mask and some calming music to sand by.Mellow
Happy building
David
#143 Posted : 11 September 2017 11:00:08
Well thats a milestone complete then DavidDrool always nice to see the hull closed offBigGrin great workBigGrin regards PhilCool
daffy09
#144 Posted : 11 September 2017 12:07:18
Thanks Phil.
I'm kinda eager to get started on the painting but I don't want to rush this next stage and spoil all my hard work.
Happy building
David
#145 Posted : 11 September 2017 23:18:09
Well done David, coming together very nicely...Cool Cool .. Look forward to your next update....
daffy09
#146 Posted : 12 September 2017 00:24:45
Thank you Alan
We're getting there. The next few days will see me out in the garden with my sanding tools and filler. I've just realised that I have to get some primer and paint before I can move on to the painting stage, and I'll need to fabricate some sort of stand/cushion out of foam or something so that the hull can be protected from accidental damage while I continue to work on her once she's painted.
happy building
David
daffy09
#147 Posted : 12 September 2017 15:28:02
Hi friends
Here's a short video of L'hermione in 2014 which may be of interest to those building this model. I found this while searching for additional info on the cannon rigging which on the model is pretty basic, to say the least, consisting of just one rope passing through the gun carriage. It's my intention to modify these features if I can find the relevant information. The video also shows the crew using footropes which are not present on our model and which I intend to include in my build somehow.
https://www.youtube.com/watch?v=e0NPjbxpy4s
Happy building
David
#148 Posted : 12 September 2017 23:06:56
Interesting video David, thanks for sharing....Cool Cool
daffy09
#149 Posted : 13 September 2017 12:05:08
Thank you Alan,
When I find anything else I'll share it on here.
The hull sanding isn't going 'smoothly'(forgive the pun). It's been too wet to do it outside and sanding on such a scale in our living space isn't going down too well with my partner and I can't say I blame her. Despite the mask, it's getting into me and isn't helping my throat problem.
Nevertheless, it will get done, but in short 'bursts'. I did try out my Dremel on her but lots of care needed to be taken not to apply too much pressure and the hull contours mean that I can only use it on the 'flat' areas anyway.
Happy building
David
daffy09
#150 Posted : 16 September 2017 20:57:21
Quick update on the L'HERMIONE build diary
Hi friends.
I'm still waiting for a dry spell so I can get outside and sand the hull. It's unfortunate that I haven't got proper workshop and have to work in our living room and it's quite understandable that my partner doesn't want sanding dust all over the house. So in the meantime, I'll just have to be patient with the weather and find something else to do - for example, I've just built the stand for her and might even have a go at the ship's boats, I don't know, it all hinges on the weather and I'd rather keep to the build order if possible.
Another thought I've had is to try to do some video clips of the build, and to that end, I've posted a small clip just as a test.
https://www.youtube.com/watch?v=xfNnwmKYCWQ
Happy building
David
#151 Posted : 16 September 2017 22:09:28
Hi David, am sure you'll get a dry spell soon so you can get on with sanding the hull down. Like the video clip, looks nice and clear.....Cool Cool
Sticky Wickett
#152 Posted : 19 September 2017 15:19:24
Hi David, it's a nice, dry day here so I hope you manage to get some sanding done. Looking good so far.Cool
Phil W.BigGrin
#153 Posted : 19 September 2017 18:31:26
BigGrin Hi david
You could always try and convince SWMiBO that a gazebo would be a perfect addition to the garden, seriously though hope the weather improves for youCool
daffy09
#154 Posted : 19 September 2017 19:15:05
BigGrin Hi david
Thanks Andy, there's a thought that could be worthwhile. In the meantime, I have managed to finish the sanding. See my next post.
Happy building
David
daffy09
#155 Posted : 19 September 2017 19:29:38
New update on the L'HERMIONE build:
STAGE 86
Hi friends,
Well as you'll have gathered, the weather in my area has been pretty inclement for the last week. So, getting rather impatient, today I took advantage of a large gap in the clouds and went outside with the sanding equipment and finished sanding the hull - it took me about 2 hours - but the result is satisfactory for me considering there is a fair amount of filling up to do now before the first priming coat.
Wanting to get something done on the build while waiting for a clear spell, I decided to jump ahead somewhat to stage 86 and build the stand which was a relatively easy job consisting of just 4 parts which need to be glued together after being removed from the parts board, given the once over with some sandpaper and assembled making sure everything was nice and square
More following;.....
Happy building
David
daffy09 attached the following image(s):
daffy09
#156 Posted : 19 September 2017 19:46:03
Continuing update on the L'HERMIONE build:
STAGE 12
Welcome back.
With the hull now sanded, work could progress on fitting the Stem, Sternpost and keel.
First off, the 5 parts were removed from the fret, burrs removed and given a light sanding all over.
The first part to be fitted was the Stem which is glued into the 4mm gap left after planking. This was quite a tight fit so nothing was needed to support it while the glue was drying.
This was followed by the 3 sections which make up the keel, again fitted into the 4mm gap along the bottom of the hull. These were held in place with masking tape until the glue dried. The last section should butt up against the Sternpost and as such, left a small gap between the 2nd and 3rd section which I filled up using an offcut of planking which was held in with superglue and trimmed off when dry.
Finally, the Sternpost was fitted after offering up to the hull and chamfering the top end to match the angle created by the sternboards under the transom. It was then glued into place and held with masking tape until the glue was dry.
That's it for this update, here's a few images of the work so far.
Happy building
David
#157 Posted : 19 September 2017 20:48:48
BigGrin Looking good David, can't wait to see the next update Cool
#158 Posted : 19 September 2017 22:35:02
Well done David, all coming together very nicely.....Cool Cool .. Look forward to seeing your next update....
daffy09
#159 Posted : 20 September 2017 00:31:42
Thanks Martyn, filling, sanding and primer next
Happy building
David
daffy09
#160 Posted : 20 September 2017 00:34:45
Thanks Alan, just had to take advantage of today's break in the cloud. It's quite a relief to get that stage done. Now it's on to the filling, more sanding and the 1st coat of primer.
Happy building
David
Guest (17)
11 Pages «<678910>»
This page was generated in 0.857 seconds.
