 Hi All Just received this kit that contains pads, sticks, fluid and cotton flannel/buffing cloth. Nine colour coded pads are included bronze being the coarse one at 1500 then 1800, 2400, 3200, 3600, 4000, 6000, 8000 and the last being gray at 12000 fine. Three sanding sticks with a different grade on each side 100MX/150MX,180MX/240MX and 400MX/600MX. A bottle of liquid abrasive and a cotton buffing cloth. Instructions are included from the manufacturer and the supplier to get the best from your kit All in all a comprehensive polishing kit that will give perfect results every time. There are several versions of the kit designed to polish various items go to the link below to see whats available:- https://www.ebay.co.uk/s...-mesh+kits&_sacat=0
Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Had this set for about 6 years. Still going strong, haven't lost their grit. I used them on canopies and flatting down for decals. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
I can also approve this mini polishing kit. The liquid polish and cloth will remove "minor" blemishes from plastic canopies and return them to a clear finish. (From my experience) Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Had this set for a long time too, all good so far. You can even put the pads in the washing machine Steve
They are very good sets indeed. I had the set some years ago but rather than the pads mine had strips of polishing material with a foam pad you wrapped them around. Lasted for ages. Happy Modelling
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,335 Points: 22,312 Location: Northamptonshire, England
I have recently bought this as well, also bought the micro mesh buds, look like cotton buds, for the hard to get at areas. They come in exactly the same coarse grades as the pads. Mark Regards Markwarren (Mark) Admin
I have been using 'Micro-mesh' for years and wouldn't be without it. Great for polishing aircraft canopies, the 12000 grit followed by a coat of 'Johnsons Klear' will leave you with a much clearer view into the cockpit than a standard kit canopy ever would even with it fully closed!
Great stuff for polishing out scratches and mould lines!!
Kev
Never used them before will have to get a set at the end of the month  thanks Andy  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Also have this pack and definitely recommend its use.
Had mine for about 3 years and its had a hammering  its a great kit I haven't used the liquid polish very much though “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
