Thanks for the kind comments guys. Malc.
The front suspension is an interesting collection of small castings. RM1 attached the following image(s):
Stacked up against the front end after a little cleaning. RM1 attached the following image(s):
White paint added to selected areas and others polished.RM1 attached the following image(s):
The suspension arm assemblies are going to be very fiddly. RM1 attached the following image(s):
Lined up with the body before further assembly.RM1 attached the following image(s):
 Looking very nice Malc, its a great feeling when all the bits clean up and slot together giving an excellent rendition of a sub-assembly Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Wow! Looking really good Malc.
Love what you are doing with this and I can see you getting hooked on these multimedia kits. Bet the car has a nice weight to it with all of that white metal in the chassis?
Keep up the good work and well done again. This car is such a cool subject!
Kev
ModelMania wrote:Wow! Looking really good Malc.
Kev  Thanks Kev. You're right about the weight. It gives it quite a special feel. Malc.
Front suspension painted and trial fitted.RM1 attached the following image(s):
Lower front arms, anti-roll bar and spring damper castings.RM1 attached the following image(s):
Some drilling needed to get the damper rods into the shocks. Then a little paint.RM1 attached the following image(s):
Finished assemblies. RM1 attached the following image(s):
Now this gets a bit tricky to assemble the shocks into the suspension. RM1 attached the following image(s):
The front end in place. RM1 attached the following image(s):
Lovely work, does look a great kit Mark Regards Markwarren (Mark) Admin
 Top work Malc, all fitting together nicely and looking good Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Looking great Malc, coming along beautifully.... Regards Alan
The suspension parts look amazing, great job Malc
Guest (14)
