37 Pages «<2829303132>»
Eaglemoss Delorean Car build (stevegbr build) Options
#581 Posted : 05 November 2017 19:56:38
stevegbr wrote:
birdaj2 wrote:
Very nice progress Steve.
Is that carpet supplied as part of the kit or is it something you have purchased as an upgrade?
no tony, got it off facebook, a guy named mike lane, does the barcode magnetic reg plate as well. well pleased.
Thanks for that Steve.
As an add on he has done a top job with the design as you have in fitting it.
Hope it all continues well.
#582 Posted : 15 November 2017 14:19:40
Have you got your issue`s yet steveConfused regards PhilCool
stevegbr
#583 Posted : 15 November 2017 14:21:56
Yes Phil. They arrived Monday mate. Will put photos on later.
stevegbr
#584 Posted : 15 November 2017 22:28:42
here is issue 44.
stevegbr attached the following image(s):
stevegbr
#585 Posted : 15 November 2017 22:30:23
here are the parts.
stevegbr
#586 Posted : 15 November 2017 22:31:05
attached the two parts to the dash.
stevegbr
#587 Posted : 15 November 2017 22:32:00
here is issue 45.
stevegbr
#588 Posted : 15 November 2017 22:32:54
here are the parts.
stevegbr
#589 Posted : 15 November 2017 22:34:21
the led circuit is attached, then secured to the dash.
stevegbr
#590 Posted : 15 November 2017 22:36:20
the underneath showing the wires.
stevegbr
#591 Posted : 15 November 2017 22:37:37
clock panel pressed in cowl.
stevegbr
#592 Posted : 15 November 2017 22:38:41
here is issue 46.
stevegbr
#593 Posted : 15 November 2017 22:39:29
here are the parts.
stevegbr
#594 Posted : 15 November 2017 22:40:21
dashboard display fitted.
stevegbr
#595 Posted : 15 November 2017 22:41:20
instrument panel with the led board inserted.
stevegbr
#596 Posted : 15 November 2017 22:42:26
wires tidied up on the rear.
stevegbr
#597 Posted : 15 November 2017 22:43:23
here is issue 47
stevegbr
#598 Posted : 15 November 2017 22:44:12
here are the parts.
stevegbr
#599 Posted : 15 November 2017 22:45:41
indicator stalks assembled.
stevegbr
#600 Posted : 15 November 2017 22:47:02
bracket to hold the steering column.
This page was generated in 0.081 seconds.
