9 Pages «<789
Pocher 1/4 ducati panigale Options
#161 Posted : 19 January 2018 22:04:51
That looks way complex Ken. I am amazed just how much detail there is packed into this model.
Its looking very good..
RM1
#162 Posted : 20 January 2018 15:54:03
Lovely looking build. Loads of details and skilfully done.
Malc.
#163 Posted : 20 January 2018 16:24:08
Nice work Ken, the detail is amazing.
kpnuts
#164 Posted : 20 January 2018 18:42:46
Hi all here is another update, all of the wiring here is added detail, none of it is supplied with the kit it makes a big difference adding it. I still don't understand why they don't supply it as 90% of the connectors are moulded and even the missing ones are easy enough to scratch build .
#165 Posted : 20 January 2018 19:45:09
Looks great Ken Cool on the home straight now.
kpnuts
#166 Posted : 21 January 2018 21:24:09
Hi all here is another update.
Bit of detailing of this bit
#167 Posted : 21 January 2018 23:29:51
Awesome build Ken.
Its incredible just how many parts are going into this one.
kpnuts
#168 Posted : 23 January 2018 21:33:27
Hi all well on the last leg of this build now.
kpnuts
#169 Posted : 24 January 2018 20:20:26
Well I've spent 3 hrs trying to get the wing mirrors on this, I may never touch the bl$€y kit again don't believe the YouTube video it's nigh on impossible. I've removed the windscreen to give me more room but still can't get them on, I really don't know how this is still in one piece.
#170 Posted : 24 January 2018 20:36:04
Ken I found it easier to remove the handlebar clip-ons first then fit the mirrors BigGrin hope that helps.
kpnuts
#171 Posted : 25 January 2018 21:23:16
Hi all well after lots of suggestions from people who have completed this kit I used a combination of their suggestions to do it I took my tamiya screwdriver which came with the tamiya bike kits (didnt want to use the one that came with the kit) broke the blade off
Cut the end off a pencil and drilled it out then glued the blade in, I now have a shorter screwdriver
Now to modify the petrol tank to be removable and to detail it up. First get my hole punch select the right size
Punch selected hole through self adhesive ally foil
Add to ignition switch
The two dome headed Allen screws on the outside of the ingition switch housing are glued in. I've drilled the holes they are supposed to screw into out so they are now locating pins, I will use the inner ones to hold the tank.
I've glued the ignition housing to the tank
#172 Posted : 25 January 2018 21:28:09
Glad you got sorted Ken BigGrin
kpnuts
#173 Posted : 25 January 2018 22:18:02
Thanks mate pleased to be past that part, is your build on here. The search bit on here is not very idiot friendly.
#174 Posted : 25 January 2018 23:09:54
Nice looking transformation Ken Cool
#175 Posted : 26 January 2018 12:54:39
I didn't put a build up Ken, just a few pics of her in the finished build gallery
http://forum.model-space...spx?g=posts&t=21022
#176 Posted : 26 January 2018 15:49:15
Lovely work Ken, Looks great. Nice idea with the pencil.
kpnuts
#177 Posted : 26 January 2018 21:20:52
Hi all this is how near I am to finishing this
I've sanded down the centre rear tyre to take the newness off it and realised I've missed the decals off the centre hub and I've weathered it now is it too late to add them now.
I'm going to alter the side panels panels to make them removable.
9 Pages «<789
