2 Pages 12>
Wingnut Wings 1/32 Roland C.IIa Late, The Build Options
#1 Posted : 13 February 2018 19:01:37
BigGrin Hi all
The review of this kit can be found here:-
http://forum.model-space...spx?g=posts&t=25879
Time for this one to get built. We start of building the inner framework that holds the pilot and observer so apart from the seats and seat belts radio's,pumps,dials with decals and levers. Once the assembly was finished and the floors weathered the whole was sprayed with a dilute 50% sepia wash.
The inner fuselage sides were painted and a wash used to bring out the plywood panel strips from the fuselage sides construction technique. The wash was applied heavier around the engine bay and fading as we go towards the tail.
More soon.
#2 Posted : 13 February 2018 21:00:34
Nice start to a cool kit Andy. Looks like that sepia wash to replicate the plywood interior is quite an effective technique.
Well done, looking good. Cool ThumpUp
#3 Posted : 13 February 2018 21:11:36
BigGrin Thanks for looking in and your comments Kev.
Most German aircraft in the 1WW were painted a light green or green-grey on all of the wood interior. The Roland having a ply skin also had the paint treatment so you can see the original colour light green in the tail area. The wash is there to represent the oil and fumes that would have passed through the fuselage from the engine. Hense it being thicker in the engine bay.
#4 Posted : 13 February 2018 21:50:49
Good stuff Andy, always nice to get a bit of history and insight into a particular subject. Cool ThumpUp
I've never really been a fan of WWI aircraft, but watching your Wingnut Wing builds and your Fokker DR.I Triplane build is slowly having an effect on me, to the point where I'd like to build something from the Great War someday? I quite fancy an SE.5a (Hispano Suiza version).
#5 Posted : 13 February 2018 23:41:45
Great to see another build on its way from you Andy, will enjoy seeing it all coe together....Cool Cool Cool Cool
#6 Posted : 14 February 2018 10:44:04
Nice build Andy, you do have some rather nice kits stashed away in places. Great work so far.BigGrin
CaptnBirdseye
#7 Posted : 14 February 2018 11:35:28
Rank: Superelite
Hi Andy,
Pleasuer to see another of your builds being created, and the insight into it's creation is ....insightful. It looks like you have an affinity with these kits Love. Another one to watch Cool
Gray
#8 Posted : 14 February 2018 12:06:57
Great start Andy Cool looks like you have another stunner in the making.
#9 Posted : 14 February 2018 19:14:33
#10 Posted : 14 February 2018 19:22:04
Spent the day building the Merc engine. Wing nuts don't supply the spark plugs you can buy resin ones as an aftermarket or make your own from 1mm tube and 0.5 wire which is the option I did making 2 per cylinder. The first couple of pics show the unpainted engine with the resin rockers and the sparkys added.
Next it was the spark plug leeds and then an assembly of the painted parts and some weathering. The last two picks show the cylinder priming cups [Brown handles] which I forgot to add until last.
More soon.
#11 Posted : 14 February 2018 21:18:03
Superb job with the engine, looks incredible.
#12 Posted : 14 February 2018 22:37:18
Very nice work on the engine Andy, those spark plugs look very convincing. Cool ThumpUp
#13 Posted : 15 February 2018 11:49:27
Looks Great AndyDrool Drool regards PhilCool
#14 Posted : 15 February 2018 19:42:13
#15 Posted : 15 February 2018 19:54:22
The single control cable for the rudder was added [ all the other control surfaces use a pushrod ] to the inner fuselage then the engine bearer was made up and the engine fitted to it after the decals had been applied. the aluminium water header tank was added along with the brass oil tank.
The above assembly was then added to an outer fuselage side and then the other side joined up. Next came the tail fin assembly, upper fuselage to cover the tail plain and lastly the 4 bracing struts.
The lower wings were prepared and glued in place along with the main undercarriage and tailskid. then the four side windows were attached.
Some masking will come next before the undercoat and then light blue base coat is added.
More soon.
#16 Posted : 15 February 2018 22:33:15
Hi looks a great kit.very tempted to get one of there's myself. Superb build so far cheers mick.
#17 Posted : 15 February 2018 22:38:39
A really great looking model, fantastic work as always.
#18 Posted : 16 February 2018 09:03:26
TRGRichie
#19 Posted : 16 February 2018 09:13:41
Very impressed with how this is looking.
Rich.
AUTO FRUMP STOMPER
#20 Posted : 16 February 2018 17:40:52
BigGrin Thanks for looking in Rich and your commentsCool
Guest (21)
2 Pages 12>
This page was generated in 0.100 seconds.
