8 Pages «<5678>
Lee's R2D2 Build Options
#121 Posted : 25 March 2018 09:23:17
Looking very nice, won’t be long before the little fellow will start chirping.BigGrin Cool
#122 Posted : 25 March 2018 13:03:18
Nice work, you will soon be onto the body.
LSainsbury
#123 Posted : 29 April 2018 11:53:22
It's that time of the month! Issues 66, 67, 68 and 69 now completed.
Only problem I had this month was screwing in one of those tiny plastic allen pins - it it's anbout half way in and I can't bet it to budge any further. Don't think it'll be an issue.
I also have another issue with I'll be posting about shortly.
LSainsbury attached the following image(s):
#124 Posted : 29 April 2018 13:34:25
Hi LSainsbury
You will have three spare allen heads once they are all fitted into the Dome so one of those can replace the problem one. It also looks like your missing a countersunk hole in the frame parts contact C/S for a replacement.
Looking good.
#125 Posted : 30 April 2018 08:58:32
Nice update Lee, coming on very nicely.
LSainsbury
#126 Posted : 26 May 2018 13:07:25
Hi LSainsbury
Looking good.
Cool - thanks for the info and yes the countersunk hole question was posted in another post and now sorted in the next update.
LSainsbury
#127 Posted : 26 May 2018 13:09:56
Happy May 2018! Another update from my R2D2 Build...
Issues 70,71,72 and 73 have arrived - along with a replacement issue 67 as I was missing a countersunk hole in one of the plates.
jennings74
#128 Posted : 28 May 2018 12:29:09
Rank: Beginner Level 1
I had some issues screwing in the plastic allen pins, if you pop them in the freezer for 10 mins or so they shrink slightly and are easier to screw in.
I’m having issues with the spacer rods that don’t have any thread to screw into, so that’s been reported to C/S. Also the miss coloured back panel BP-07 that doesn’t line up correctly without leaving a gap at the bottom and a step at the top. I just can’t get it to line up no matter how I try, so I’ve also requested a replacement part.
LSainsbury
#129 Posted : 17 June 2018 17:41:35
Issues 74,75,76 and 77:
Received my replacement issue 68 panel but it still looks a bit off. The white on the inside is more white than outside. It's a better fit though but still has a bit of step at the top.
#130 Posted : 17 June 2018 18:14:31
Nice work Lee. Looking excellent.Cool
Ritchie69
#131 Posted : 17 June 2018 18:42:26
Looking good Lee, 3/4 the way through BigGrin
Peter
Completed - R2D2
#132 Posted : 17 June 2018 19:11:40
BigGrin Coming together nicelyCool
#133 Posted : 17 June 2018 19:27:13
Lovely progress, heading towards the final straights now....Cool Cool
lholland
#134 Posted : 18 June 2018 11:03:03
Looking Good, very exciting times now BigGrin BigGrin
LSainsbury
#135 Posted : 28 July 2018 13:49:51
Issues 78, 79, 80 and 81.
Once again I nearly had a screw mishap with issues 78 while putting the tool arms together!!
All good now though.
#136 Posted : 29 July 2018 07:15:35
BigGrin Looking good and starting to come together nowCool
LSainsbury
#137 Posted : 29 July 2018 18:08:07
Yes - my screw issue was that I used some long black - think they were 11mm screws to attach the small hinges to the tool door. The actual tools are using the correct long half threaded screws - I'm sure there should have been two more for those hinges.
Can you confirm what the correct screws should be?
#138 Posted : 29 July 2018 18:14:29
If you check the official build diary for issue 78 it confirms what screws are to be used for this part of the assembly. Always check the official build if you are unsure of something.
#139 Posted : 30 July 2018 07:35:08
Nice work Lee
Spudtrooper37
#140 Posted : 15 August 2018 13:39:24
Another little R2 coming along nicely 😁
Darren
Have an AWSOME day and may the Force be with you always 😉
Building: Millennium Falcon https://forum.model-spac...sts&t=14381&p=7 - Building: BTTF Delorean - Building: Dom's Dodge Charger
- Building : X-Wing https://forum.model-spac...aspx?g=posts&t=34899
8 Pages «<5678>
This page was generated in 0.095 seconds.
