This is a lovely kit, very well put together. Very impressive. Mark Regards Markwarren (Mark) Admin
love the deck plating and the etch bridge this kit is turning out to be something a bit special nice build Andy “Whenever you find yourself on the side of the majority, it is time to pause and reflect.” -Mark Twain
 Thanks for looking in and your comments everyone Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Looks great Andy..... Regards Alan
Looking very nice Andy and some high quality etch provided around the superstructure by the look of it too.
Well done.
Kev
The etch looks perfect  was it easy to bend i no some older etch is a little thick  looks like a great kit so far Andy  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Joined: 19/05/2015 Posts: 1,419 Points: 4,272 Location: Darmstadt, Germany
Wow, you're fast. This looks amazing. Such a nice kit.
Looking great Andy, you must be working 24/7 on this.
Joined: 26/05/2015 Posts: 121 Points: 366 Location: Wexford, Ireland
looking great!  lovely details on the bridge carcase! regards, Arek
 Thanks for looking in and your comments everyone. The etch provided is fine and of different thicknesses the side wall plates being the thickest then thinner again for medium bends and even thinner for the rounded front of the bridge. I mostly work from home these days so have lots of time to complete both work and other commitments. Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi all The bridge doors, downpipes, trunking, brackets and rails have all been added to the sides. After that the upper bridge splinter deflectors were added to the upper front bridge and sides and the mid height splinter deflectors added to the forward bulkheads. More soon. Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Hi looking really nice,like the brass work .cheers mick. Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
A good clean build on the superstructure Andy  nicely done. Al
 Hi all After the hull paint cured inspection found still a lot to do so it was out with more filler and then another sanding back. I have also drilled out the port holes using the templates provided and filled the drill holes with pre-cut 5mm x 2mm brass tube included in the kit. More soon. Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
 Hi all The hull has had the bilge keels fitted along with the rubbing strips and some etch covers added. Next its more deck furniture starting with the central deck spine made up from wood and ply then covered top and sides with the deck plates. The nest item was the funnel base lots more etch added here along with lots of doors and wheels. The next thing to be built is the rear gun station the carcase has been made up and the brass started to be added the top deck has been covered in plates. More soon. Andy arpurchase attached the following image(s): Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Great update Andy  looks a real nice kit  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
Coming along at a rate of knots now Andy  nice going. Al
It's really starting to take shape, looking good.
Great work Andy.  I just love the detail and quality of this kit, and you are making it look so easy. Mark Regards Markwarren (Mark) Admin
