Hi only got up to stage 8 on this so far,but thought I'd start with the wheel.as it been lil tricky from the diaries I have read.I did not use the double sided tape method would not hold.i used canopy glue.though you do have to let it set a while.this held it OK.spokes B were fiddly ones to thread through.all in all a fiddly job but I got on OK with it. Took me 3 hrs. Cheers mick.ill put up better pics as only just finished it and they not that good at night.cheers mick. mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Hi got 36 issues of this now, so thought I'd make a start Issue 1 Parts Bonnet Motif bar in air take aperture Motif (jaguar growler badge) Left hand hub cap Simple enough just put growler badge in motif bar, cheers mick. mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Hi issue 2 Parts Leather seat cushion Cylinder head Inlet camshaft Exhaust camshaft Inlet cam cover Exhaust cam cover Oil cap First of all attach the oil cap to cover via screw from back, push in both camshafts, push on camshaft covers, cheers mick. mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Issue 3 Parts Horn button Steering wheel Spare tyre This issue is just push the horn button onto the steering wheel, cheers mick. mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Issue 4 and 5 This just covers making up the wheel, and fitting the tyre, as in previous pics,I'll do more indepth pics on this next wheel I get. Cheers mick. Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Issue 6 Parts Drivers door Door handle This issue we simply attach the door handle via screw from the back of door. Cheers mick mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Issue 7 Parts Drivers door window Hinge Hinge retainer In this issue we simply attach the door hinge and window, screwing them to the door. Cheers mick. mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Issue 8 Parts Drivers door trim surround Drivers door trim panel Drivers door handle Drivers window regulator handle Chrome finisher upper Chrome finisher lower Arm rest This issue we carry on fitting various parts to the inside of the drivers door,all attached via screws apart from the chrome trims which are push in, it is possible to fit these the wrong way round, look closely and you will see one end of chrome finishers has a slightly angle, to match the angles on the door, you will soon see if it wrong they will protude, just outside of door edge.cheers mick. mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Issue 9 Parts Drivers seat frame Drivers seat backrest Here we simply push on the backrest, and put in the seat cushion from issue 2 just a press fit these. Cheers mick. mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Issue 10 Parts Manifold assembly (upper half) Throttle linkage Shaft Suction chambers 3 Here we feed the Shaft through the throttle linkage, and screw this to the Manifold assembly. Cheers mick. mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Issue 11 Parts Manifold assembly (lower half) Petrol feed pipe Air balance pipe Air cleaner First of all screw together the 2 half's of the Manifold assembly, attach the Suction chambers x3, fit the petrol feed pipe, then the air balance pipe,and fit the aircleaner. Cheers mick mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Issue 12 Parts Engine block and clutch bellhousing (right side) Starter motor Distributor This issue we decide if we want to repaint the engine block, black gold,and silver to pick out the bolts,also painted the top and bottom of the distributor black, the starter motor was deseamed and painted black,then it's fit the starter motor, the distributor, then add the carburettor assembly, cheers mick. mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Issue 13 Parts Engine block and clutch housing (left side) Battery box Filter head and hose Here I painted the other side of the block as shown, and painted the filter head and hose,then it's fit the filter head and hose to the engine right hand side,then it's fit the battery box to the left hand side of engine. Cheers mick. mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Issue 14 Parts Engine breather Ignition coil half's Ignition lead Dynamo Dynamo end cap Timing chain cover Pulley Fan belt and pulleys Here we do bit more painting to the end of the ignition coil, painted the cylinder head silver as shown, the fan belt and pulleys I cleaned it up then painted it semi gloss black, painted the belt rubber black, and the bolts silver. Then insert the ignition lead and screw together the half's of the ignition coil, attach this to the cylinder head, I cleaned up the seam on the engine breather and repainted it, then attach this to the cylinder head the dynamo was also deseamed and repainted, the large pulley I filled the ejector marks and repainted it, then put this belt assembly together. Cheers mick. mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Issue 15 Parts Plug leads Forward exhaust Manifold Rear exhaust Manifold Rev counter generator connector Here I deseamed the exhausts manifolds, and repainted them, before attaching them to the engine, add the Rev counter generator connector, then attach the cylinder head, route the wire to the battery holder, place the pulley belt in place and screw the half's of the engine together, then put the ignition coil and plug leads in. Cheers mick. mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Off to a great start Mick, you're certainly powering on with her..... All looking good....
Great to see more of your jag Mick  nicely done. Al
 Looking good Mick and nice start Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Nice start, coming on very nicely. Mark Regards Markwarren (Mark) Admin
Got going nicely Mick. Looks good. Malc.
Guest (12)
