5 Pages 123>»
micks E type jag build Options
#1 Posted : 04 January 2018 22:56:05
Hi only got up to stage 8 on this so far,but thought I'd start with the wheel.as it been lil tricky from the diaries I have read.I did not use the double sided tape method would not hold.i used canopy glue.though you do have to let it set a while.this held it OK.spokes B were fiddly ones to thread through.all in all a fiddly job but I got on OK with it. Took me 3 hrs. Cheers mick.ill put up better pics as only just finished it and they not that good at night.cheers mick.
#2 Posted : 21 July 2018 18:09:41
Hi got 36 issues of this now, so thought I'd make a start
Issue 1
Parts
Bonnet
Motif bar in air take aperture
Motif (jaguar growler badge)
Left hand hub cap
Simple enough just put growler badge in motif bar, cheers mick.
#3 Posted : 21 July 2018 18:18:06
Hi issue 2
Parts
Leather seat cushion
Cylinder head
Inlet camshaft
Exhaust camshaft
Inlet cam cover
Exhaust cam cover
Oil cap
First of all attach the oil cap to cover via screw from back, push in both camshafts, push on camshaft covers, cheers mick.
#4 Posted : 21 July 2018 18:23:25
Issue 3
Parts
Horn button
Steering wheel
Spare tyre
This issue is just push the horn button onto the steering wheel, cheers mick.
#5 Posted : 21 July 2018 18:26:57
Issue 4 and 5
This just covers making up the wheel, and fitting the tyre, as in previous pics,I'll do more indepth pics on this next wheel I get. Cheers mick.
#6 Posted : 21 July 2018 18:30:02
Issue 6
Parts
Drivers door
Door handle
This issue we simply attach the door handle via screw from the back of door. Cheers mick
#7 Posted : 21 July 2018 18:35:29
Issue 7
Parts
Drivers door window
Hinge
Hinge retainer
In this issue we simply attach the door hinge and window, screwing them to the door. Cheers mick.
#8 Posted : 21 July 2018 18:45:55
Issue 8
Parts
Drivers door trim surround
Drivers door trim panel
Drivers door handle
Drivers window regulator handle
Chrome finisher upper
Chrome finisher lower
Arm rest
This issue we carry on fitting various parts to the inside of the drivers door,all attached via screws apart from the chrome trims which are push in, it is possible to fit these the wrong way round, look closely and you will see one end of chrome finishers has a slightly angle, to match the angles on the door, you will soon see if it wrong they will protude, just outside of door edge.cheers mick.
#9 Posted : 21 July 2018 19:10:42
Issue 9
Parts
Drivers seat frame
Drivers seat backrest
Here we simply push on the backrest, and put in the seat cushion from issue 2 just a press fit these. Cheers mick.
#10 Posted : 21 July 2018 20:07:19
Issue 10
Parts
Manifold assembly (upper half)
Throttle linkage
Shaft
Suction chambers 3
Here we feed the Shaft through the throttle linkage, and screw this to the Manifold assembly. Cheers mick.
#11 Posted : 21 July 2018 20:15:24
Issue 11
Parts
Manifold assembly (lower half)
Petrol feed pipe
Air balance pipe
Air cleaner
First of all screw together the 2 half's of the Manifold assembly, attach the Suction chambers x3, fit the petrol feed pipe, then the air balance pipe,and fit the aircleaner. Cheers mick
#12 Posted : 21 July 2018 20:26:24
Issue 12
Parts
Engine block and clutch bellhousing (right side)
Starter motor
Distributor
This issue we decide if we want to repaint the engine block, black gold,and silver to pick out the bolts,also painted the top and bottom of the distributor black, the starter motor was deseamed and painted black,then it's fit the starter motor, the distributor, then add the carburettor assembly, cheers mick.
#13 Posted : 21 July 2018 20:37:28
Issue 13
Parts
Engine block and clutch housing (left side)
Battery box
Filter head and hose
Here I painted the other side of the block as shown, and painted the filter head and hose,then it's fit the filter head and hose to the engine right hand side,then it's fit the battery box to the left hand side of engine. Cheers mick.
#14 Posted : 21 July 2018 20:52:47
Issue 14
Parts
Engine breather
Ignition coil half's
Ignition lead
Dynamo
Dynamo end cap
Timing chain cover
Pulley
Fan belt and pulleys
Here we do bit more painting to the end of the ignition coil, painted the cylinder head silver as shown, the fan belt and pulleys I cleaned it up then painted it semi gloss black, painted the belt rubber black, and the bolts silver. Then insert the ignition lead and screw together the half's of the ignition coil, attach this to the cylinder head, I cleaned up the seam on the engine breather and repainted it, then attach this to the cylinder head the dynamo was also deseamed and repainted, the large pulley I filled the ejector marks and repainted it, then put this belt assembly together. Cheers mick.
#15 Posted : 21 July 2018 21:02:26
Issue 15
Parts
Plug leads
Forward exhaust Manifold
Rear exhaust Manifold
Rev counter generator connector
Here I deseamed the exhausts manifolds, and repainted them, before attaching them to the engine, add the Rev counter generator connector, then attach the cylinder head, route the wire to the battery holder, place the pulley belt in place and screw the half's of the engine together, then put the ignition coil and plug leads in. Cheers mick.
#16 Posted : 21 July 2018 23:41:59
Off to a great start Mick, you're certainly powering on with her..... All looking good....
#17 Posted : 21 July 2018 23:49:38
Great to see more of your jag MickBigGrin nicely done.
#18 Posted: : 22 July 2018 07:40:20
BigGrin Looking good Mick and nice startCool
#19 Posted : 22 July 2018 09:20:08
Nice start, coming on very nicely.Cool
RM1
#20 Posted : 25 July 2018 09:46:27
Got going nicely Mick. Looks good.
Malc.
Guest (20)
5 Pages 123>»
This page was generated in 0.188 seconds.
