 Looking good Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,335 Points: 22,312 Location: Northamptonshire, England
Looking excellent, some very clever work going on. Mark Regards Markwarren (Mark) Admin
Beautiful work, excellent display of scratch building.... Regards Alan
Joined: 26/12/2012 Posts: 140 Points: 418 Location: Plymouth
Ok so i have mocked it up on the wing to give you an idea of size and yep its big  from tip to tip she's about 18" don't even want to think where its gonna go. The tube slots work perfect so big sigh of relief next issue its going to take some base to keep this sucker upright, next big issue to resolve to create the effect I want. I decided to use black milliput for the veins on the wing tips so there is built in shadow if needed, just one piece of advice about using black milliput DON'T its a nightmare this better work. godan61 attached the following image(s):
May be big but it also looks incredibly fragile and easily broken, take it you will be placing the completed build in a display case.... Stunning work.... Regards Alan
Amazing work, WTG Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
 Coming together nicely Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Incredible work, coming on very nicely. Mark Regards Markwarren (Mark) Admin
Its coming along really well  a lot of skilful work involved. Al
Just love the way this is progressing. Keep up the good work. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Thanks guys its certainly testing the limits of developing new skills but enjoyable.
looks stunning. Current builds.Hachettes build the bismark,HMS Victory, HMS Hood. Finished Builds Corel HMS Victory cross section.
Ok so before I can go any further I need a base, something heavy enough that it will balance the height of it. What to do?????/ So my solution is get a rock a big rock and make it look like part of the floating mountains and after a few days I found the right one, but how to secure it. I drilled 2 holes n the rock and inserted 2 tubes for the leg pins. Using a disc cutter I cut the bottom off the stone and then inset it in an MDF plinth then fixing it with a couple of screws and some grip fill. And presto a base heavy enough to take its weight, later I will paint it add detail at the base and mount it on a plinth. godan61 attached the following image(s):
Excellent build, this is going to look so good. Mark Regards Markwarren (Mark) Admin
This is looking so good, excellent work..... Regards Alan
 Looking good and nice work Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
That's a great looking base to display Toruk on  very natural. Al
That's one huge display. Looks awesome well done. Chris On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
Looks amazing  will be a stunner when completed  well done  regards Phil COMING SOON =1/72 Italeri diorama`s Battle for the Reichstag and Stalingrad battle at the tractor factory 1/16 Trumpeter King Tiger with loads of extras ON THE GO= refurbishment of 1/25 Tamiya tiger 1 , amt Star trek kits and space 1999 models
