80 Pages «<910111213>»
Sticky Wickett
#201 Posted : 27 September 2018 07:33:48
The conning tower deck being checked for fit.
Sticky Wickett
#202 Posted : 27 September 2018 07:37:01
I then removed the conning tower deck and proceeded to fit two part-works supplied pieces that make up the interior profile.
The attached photo shows where the port side section will be fitted.
Sticky Wickett
#203 Posted : 27 September 2018 07:38:20
Port interior section fitted.
Sticky Wickett
#204 Posted : 27 September 2018 07:39:24
The starboard section being fitted.
Sticky Wickett
#205 Posted : 27 September 2018 07:42:23
I then glued in place the conning tower main deck as mentioned before and filed the corners of the square strip, as seen here, to allow for supports to be added.
#206 Posted : 27 September 2018 08:02:18
Amazing work as usual. Love
Sticky Wickett
#207 Posted : 27 September 2018 08:06:43
The attached photo shows the first of two supports I made that act to 'blank off' the void in the vee sections of the upper and lower decks. These supports also double up as a 'step-down' into the main conning tower deck as per U995 and provide support for the upper deck.
Sticky Wickett
#208 Posted : 27 September 2018 08:08:25
Thank you Mark!Cool
Phil W.
Sticky Wickett
#209 Posted : 27 September 2018 08:08:54
First support piece fitted.
Sticky Wickett
#210 Posted : 27 September 2018 08:09:33
Second support piece fitted.
Sticky Wickett
#211 Posted : 27 September 2018 08:15:22
I then spent a bit of time adding filler to any gaps and sanding all of these parts true. During this time I also glued in place the upper deck and left it overnight to cure. The next step, as seen in the attached photo was to mark out where the tapered profile that sits underneath the upper deck will locate and fit additional strengthening strips.
Sticky Wickett
#212 Posted : 27 September 2018 08:17:01
Starboard side showing the support piece in place underneath the upper deck. You can also see the marking out which I will use as a guide for the tapered sections.
Sticky Wickett
#213 Posted : 27 September 2018 08:20:12
The next job was to make the first two tapered sections that connect the upper deck to the main conning tower body.
The attached photo shows these two pieces cut out.
Sticky Wickett
#214 Posted : 27 September 2018 08:22:43
The attached photo shows the first tapered section on the port side. I taped it in place to ensure the correct location and added small beads of glue to fix it.
Sticky Wickett
#215 Posted : 27 September 2018 08:23:30
From another angle.
Sticky Wickett
#216 Posted : 27 September 2018 08:24:19
The same tapered section on the port side from another angle.
Sticky Wickett
#217 Posted : 27 September 2018 08:25:39
Starboard side tapered section, taped and glued in place.
Sticky Wickett
#218 Posted : 27 September 2018 08:26:38
Starboard tapered section from another angle.
Sticky Wickett
#219 Posted : 27 September 2018 08:28:11
Rear view of the conning tower showing the first two tapered sections in place. Before i remove the tape I will add further supports to strengthen these pieces.
Sticky Wickett
#220 Posted : 27 September 2018 08:31:22
That concludes this weeks update. Next week I will continue adding the remainder of the tapered sections connecting the upper deck to the main conning tower body.
Thanks for looking in and your comments, have a great weekend and happy modelling!BigGrin
Phil W.
This page was generated in 0.406 seconds.
