Great progress, looking good.
Joined: 29/01/2017 Posts: 177 Points: 546 Location: Corby, UK
Thanks all for your kind words Completed - R2D2
Joined: 15/11/2017 Posts: 19 Points: 60 Location: France
Hello, someone has news about the camera ? The head is almost finished, but still no camera !! Thanks
Rank: Administration         Groups: Registered, Administrators, Global Forum Support, Moderator, Forum Support Team, Official Builds Joined: 04/01/2016 Posts: 7,421 Points: 22,573 Location: Northamptonshire, England
Perahim wrote:Hello, someone has news about the camera ? The head is almost finished, but still no camera !! Thanks It will be fitted at the latter part of the build. Regards Markwarren (Mark) Admin
This is all looking very good and at this rate you could have a working R2 in time for Christmas. Keep up the good work. Regards delboy271155 (Derek0 COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Not long now to the end of the build. I can't wait to have a little R2 moving around the house So onto the next issues of the build. Issue 89In this issue we get the following parts. One side of the centre foot, mounting plate and foot details. Assemble the leg details then attach to the centre foot. Ritchie69 attached the following image(s): Completed - R2D2
Issue 90We get the following in this issue, the second side of the centre foot, foot details and foot bumper. Assemble the foot details the attach to the centre foot. Ritchie69 attached the following image(s): Completed - R2D2
Issue 91aWe get the following in this issue, the base for the centre foot, centre foot sensor, a castor, micro switch, cable tidies, leg pivot cover and more screws & nuts. Attach the micro switches to the foot base, then add the sensor. Secure the micro switches in place. Attach the castor and secure with a washer, spring washer and nut. Take both sides of the centre foot from issues 89 & 90, with the base in this issue. Thread the wires through the foot support then attach to one side of the centre foot. Add the details and the bumper bar then close both sides of the foot and screw together. Fit the base to both parts of the foot and screw into place. Ritchie69 attached the following image(s): Completed - R2D2
Issue 91bTake both completed legs, the cable tidies and the body frame. Wind the cable tides around the wires. Then tread the wires through each shoulder joint in the body frame and attach them. Attach the leg pivot cover to both legs. Take the base from issue 88 and attach to the bottom of the body frame. Then attach the centre leg to the bottom. Ritchie69 attached the following image(s): Completed - R2D2
Issue 92In this issue we get the battery box & charger. (This has been updated now we have the issue)  Ritchie69 attached the following image(s): Completed - R2D2
Issue 93In this issue we get the following, circuit board cover, circuit board bracket and battery box bracket. Take the main R2 assembly and attach the battery bracket into the body at the bottom. Then take the circuit board from issue 52 and the circuit board cover, and place the circuit board into the cover and secure with self tapping screws. Attach to the circuit board bracket and place into the body frame above the battery bracket. Ritchie69 attached the following image(s): Completed - R2D2
Looks great
Certainly taking shape now. Not far to the finish line. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Very nice indeed and nicely presented too...  .. The end is nigh.... Regards Alan
Nice work Pete, very tidy work. Not long now. Mark Regards Markwarren (Mark) Admin
Joined: 04/05/2011 Posts: 173 Points: 528 Location: Sussex
looks great. Nearly there and now time for the bells and whistles.
Coming close to the end now and looking great, nice work.
 Looking good and nice work Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Thanks all. Yep, the ‘end is nigh’ 2 more months and it will be complete. Completed - R2D2
