80 Pages «<1314151617>»
Sticky Wickett
#281 Posted : 11 October 2018 08:03:15
Fairing removed to show the first pilot holes I drilled.
Sticky Wickett
#282 Posted : 11 October 2018 08:04:57
I then drilled a few more holes to open out the sections, replaced the fairing and broke out the mini grinder!Blink
Sticky Wickett
#283 Posted : 11 October 2018 08:05:29
From another angle.
Sticky Wickett
#284 Posted : 11 October 2018 08:07:09
I then removed the fairing again and continued to grind out the slots that will form the diesel engine air intakes.
Sticky Wickett
#285 Posted : 11 October 2018 08:07:48
Work in progress.
Sticky Wickett
#286 Posted : 11 October 2018 08:08:54
Working on the other intake. It all looks quite scruffy at the moment.Blink
Sticky Wickett
#287 Posted : 11 October 2018 08:10:11
I then cut these sections from the main fairing and glued them in place onto the conning tower.
Sticky Wickett
#288 Posted : 11 October 2018 08:14:40
After a couple of hours filing and shaping I eventually managed to get the inlets to look the part.
Sticky Wickett
#289 Posted : 11 October 2018 08:15:11
From another angle.
Sticky Wickett
#290 Posted : 11 October 2018 08:15:43
Looking from above.
Sticky Wickett
#291 Posted : 11 October 2018 08:18:50
Because I had filed a lot of the height away, I had to make this up difference so the inlets would be level with the top of the fairing again.
I used a section of 2.5mm square strip for this job, checking the level against the remainder of the fairing.
Sticky Wickett
#292 Posted : 11 October 2018 08:20:03
Once happy that I had the correct height, I cut out another piece and glued both in place.
Sticky Wickett
#293 Posted : 11 October 2018 08:21:01
This was then followed by lots more filing and shaping.
Sticky Wickett
#294 Posted : 11 October 2018 08:22:09
Filing and shaping on port intake completed.
Sticky Wickett
#295 Posted : 11 October 2018 08:22:50
Looking from the rear.
Sticky Wickett
#296 Posted : 11 October 2018 08:23:41
Starboard side completed.
Sticky Wickett
#297 Posted : 11 October 2018 08:24:28
Filler applied.
Sticky Wickett
#298 Posted : 11 October 2018 08:25:04
From another angle.
Sticky Wickett
#299 Posted : 11 October 2018 08:25:45
Filler sanded.
Sticky Wickett
#300 Posted : 11 October 2018 08:29:01
That concludes this weeks update. As I write I have on order some fine steel mesh from The Mesh Company to top these intakes and will cover the fitting next week before moving on to more 'cutting and shutting' of the conning tower.
Thanks for looking in and your comments, have a great weekend and happy modelling!BigGrin
Phil W.
This page was generated in 0.246 seconds.
