80 Pages «<1617181920>»
Sticky Wickett
#341 Posted : 18 October 2018 08:40:49
Third bar fitted.
Sticky Wickett
#342 Posted : 18 October 2018 08:41:30
From another angle.
Sticky Wickett
#343 Posted : 18 October 2018 08:43:08
I used the same size wire mesh for the air intakes, to make the 'mesh antennae'.
The attached photo shows the mesh cut to shape.
Sticky Wickett
#344 Posted : 18 October 2018 08:44:08
Wire mesh fitted.
Sticky Wickett
#345 Posted : 18 October 2018 08:44:52
Looking from the other side.
Sticky Wickett
#346 Posted : 18 October 2018 08:45:29
From another angle.
Sticky Wickett
#347 Posted : 18 October 2018 08:47:22
I then drilled out the 1.0mm diameter centre hole in the base with a 2.0mm drill to except the brass rod which will form the mast.
Sticky Wickett
#348 Posted : 18 October 2018 08:48:22
The 2.0mm diameter brass rod being checked for fit.
Sticky Wickett
#349 Posted : 18 October 2018 08:49:19
From one angle.
Sticky Wickett
#350 Posted : 18 October 2018 08:51:16
From another angle.
Sticky Wickett
#351 Posted : 18 October 2018 08:55:08
The next step was to add a mast support that fits underneath the base. I cut a small section from 3.0mm diameter aluminium tube, 2.0mm internal diameter, slid it along the brass rod and glued in place, knowing that it would be central and remain fixed once the brass rod was removed.
Sticky Wickett
#352 Posted : 18 October 2018 08:57:00
Brass rod removed showing the aluminium bush in place. The brass rod that will form the mast will be fitted later.
Sticky Wickett
#353 Posted : 18 October 2018 08:57:41
From another angle.
Sticky Wickett
#354 Posted : 18 October 2018 08:59:45
The next very fiddly stage was to make the 16 dipoles that are fitted to the wire mesh. I used 0.5mm diameter brass rod for this job.
The attached photo shows the first one bent to shape. Another 15 to make!Blink
Sticky Wickett
#355 Posted : 18 October 2018 09:00:22
16 dipoles made.
Sticky Wickett
#356 Posted : 18 October 2018 09:03:40
The next phase was to make the 8 brackets that housed two dipoles each. Each bracket was made from 2.0mm wide x 0.5mm thick plastic strip. I had to make a few of these to allow for mistakes, as each piece measured 3.0mm long with two 0.5mm diameter holes drilled through each piece to except the dipoles. Patience required here!
Sticky Wickett
#357 Posted : 18 October 2018 09:04:46
One completed bracket with two diploes fitted. Very, very small! Another 7 to make!Blink
Sticky Wickett
#358 Posted : 18 October 2018 09:05:31
All brackets and dipoles constructed.
Sticky Wickett
#359 Posted : 18 October 2018 09:07:44
Brackets and dipoles fitted to the FuMO-30 wire mesh radar antennae. The top row is off set to the bottom row as per U995.
Sticky Wickett
#360 Posted : 18 October 2018 09:08:28
Rotated round.
This page was generated in 0.137 seconds.
