This will be my entry into the "Last Year of the Panavia Tornado" competition. Basic pics are attached below and more pics to come of the contents and some tasty additional bits and pieces. Good luck to all entrants. Regards delboy271155 (Derek) delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Nice one Derek, good luck in the competition. Mark Regards Markwarren (Mark) Admin
Another great Tornado entry, good luck
Nice choice Del and good luck in the competition Regards Gray
Good luck with your entry Derek, will enjoy following.... Regards Alan
Good luck Derek. Look forward to seeing your build start. Chris 😎 On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
 Looks a nice kit and good luck in the comp Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Joined: 25/03/2011 Posts: 1,027 Points: 3,075 Location: Lincolnshire
Good luck Derek, nice to see someone else taking on the F-3, will be following.
Got a couple of these in the stash so will be watching  good luck in the comp. Al
Thanks for all the encouraging comments. Now there`s shed loads of after market stuff out there and my choice is shown in the pics below after the the kit contents. Brass etch I`m comfortable with, but the jet engine parts in resin are a first for me so depending how it goes I may revert to the kit parts. So here`s the kit and after market pics. Just got to sort paints if not already in my ever expanding collection. Regards delboy271155 (Derek) delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
 Hi Derek Some nice extras there and dont worry to much about the Aires resin if you look at the instructions [if you can call them that  ] the dark casting block parts shown in the instructions are what needs to be removed to create the part. Cut 2 to 3mm away from the part edge when removing the casting block then trim/sand back once the part is released. Also be carefull when triming/ sanding not to remove detail as resin parts can also be fragile if handled roughly. Resin parts can be quite daunting if you have never used them before but once you have one under your belt its plain sailing for future projects. Have fun Andy Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
I looking forward to seeing this come together. Mark Regards Markwarren (Mark) Admin
Hi look forward to following your build on this.cheers mick. Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Great set of Detail sets. Look forward to seeing what you do with your build.
Good Luck Chris 😎On the bench 1/350 Revell Tirpitz Platinum Edition (Pontos PE and Wooden deck) plus extra Eduard PE set and extra MK1 door sets.
I have a small update on the start of this build. I have got some parts ready for a base coat of paint, leaving some sprue on for something to keep hold on and I have removed all the instrumentation, foot pedals and foot pedal runners from the cockpit. Pic 1 shows the seat part for both crew members. Pic 2 shows the lower fuselage and front wheel bay. Pic 3 shows the cockpit and the arrows indicate where the detail has been removed in preparation for the etch upgrades. These parts now have a base coat and are drying ready for the next stages. Regards delboy271155 (Derek) delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
 Nice start on the little beasty Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Nice start, looking forward to seeing this take shape. Mark Regards Markwarren (Mark) Admin
Thanks to those who have looked in and and the kind comments. Another small update: I`ve painted the seat frames and constructed one to show how the parts come together. Also painted the cockpit sides in preparation for the etch control panels. Next job here is to fit the etch foot pedals and rails before painting the cockpit floor. I`ve made a start on removing the detail from the seat backs and bases as the complete seat belt system is to be replaced by etch detailing. Progress pics below. Regards delboy271155 (Derek) delboy271155 attached the following image(s): COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
Good to see another update
Guest (15)
