Issue 33 Parts Radiator front and back.cowl and hose, Here we fix the water pump and hoses to the front of the engine,I deseamed the rad and repainted it semi gloss black, and picked out the bolts in silver, then painted the hoses rubber black after deseamed them, then fit in the engine, the distributor connectors, the oil filter, then added the Sump to the bottom of the engine. I had to scrape the pins for lighter fit, so it's comes off easier to fit battery's, lost the pics to this stage, but it can be seen in later issues.cheers mick. mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Issue 34 Parts Front bulkhead Here we assemble the radiator,and fit it to the front of the previous assembly and connect the hoses to it,cheers mick. mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Issue 35 Parts Reservac tank Brake servo unit Fluid reservoirs Fuel filter Clip Brake vacuum hoses Hydraulic and fuel pipes Here we fit all the above to the front bulkhead. mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Issue 36 Parts Windscreen wiper motor Engine stabiliser mounting Throttle linkage Voltage control unit Reservoir bracket Washer reservoir washer cap,heater water control tap, washer tube, heater motor,heater,case all theses parts are fitted to the front bulkhead. Cheers mick. mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Issue 37 Parts Left hand mudshield, right hand mudshield, battery leads, battery,gearbox mountings here we attach the front bulkhead to the previous assembly. Cheers mick. mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Issue 38 Parts wheel rim Inner spokes Here we attach the battery's leads to battery, then attach this to the left mudshield, then this is attached to the rest of the assembly. mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Issues 39 to 41 deal with the assembly of a wheel,I just followed spal guide to this,the top one is the spare, with 2 spoke crossover, I'll leave this one like this,the bottom one is 3 spoke crossover which I'll use on the other 3 that go on the car.cheers mick. mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Issue 42 Parts Front floor assembly Here there is no assembly in this stage.cheers mick. mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Issue 43 Parts rear floor assembly Here we screw the 2 half's of the floor together. Cheers mick. mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Issue 44 Parts lower casing, Upper casing, right hand rear brake,left hand rear brake,right and left hand universal joints,bonnet catch Here we assemble the parts in this issue which make up the final drive unit.and attach the bonnet catch. Cheers mick. mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Issue 45 Parts rear subframe. Handbrake linkage Here we fit the final drive unit from the last issue into the rear subframe,then fix the handbrake linkage to this. Cheers mick. mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Issue 46 Parts shock absorber body's, shock absorber pistons,coil springs,hub carrier,left hand wishbone Left hand half Shaft, universal joint,mounting plate,long spindle,medium spindle,short spindle. Here we put together the rear shocks first, I deseamed mine and painted them, then it's fit these into the subframe, fit the universal joint into the half Shaft,then fit this to the final drive unit, then add the wishbone to complete this assembly on this side.cheers mick. Forgot to add put the hub carrier in as well mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Issue 47 This is identical to issue 46,just the opposite side. Cheers mick. mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Issue 48 Parts rear anti roll bar,bracing plate,right and left radius arms,mounting brackets,safety straps,links. Here we first attach the links to the anti roll bar then attach the radius arms to this,we then fit this assembly to the car bottom,then fit the subframe previously built up to the bottom of car,then fit the bracing plate to subframe.cheers mick. mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
Issue 49 Parts silencer upper and lower half's, Here we screw the 2 half's of the silencer together, then screw this to underside of car,as as far as got for now,more wheels next,cheers mick. mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
You certainly have made a lot of progress Mick  nicely done. Al
Looking good Mick. Regards delboy271155 (Derek) COME BACK GUY FAWKES "YOUR COUNTRY NEEDS YOU"
 Coming along nicely Mick Current builds:-C57,Zero, Lamborghini Countach, Caldercraft HMS Agamemnon,Robi,R2-D2, MFH Cobra .
Looking good Mick. Mark Regards Markwarren (Mark) Admin
Hi thanks to all who looked in and left comments much appreciated. Issues 50 to 52 is just another wheel, first one took about 4 hrs to do this one an hour,must be getting use to the Lil so an sos now, that's me fully up to date on this,cheers mick. mogwai attached the following image(s): Builds hms victory, suzuki gsx 1300 R hayabusa, honda C B 750, lamborghini countach L P 500 S, tamiya 1/16 rc full option tiger 1 tank, built, Mclaren M P 4 - 23. Occre london tram, Stash.airfix 1/24 mosquito. Diag Virginia schooner, tamiya 1/6 honda 750, tamiya 1/35 famo, tamiya 1/35 flak 88.
