80 Pages «<2122232425>»
Sticky Wickett
#441 Posted : 09 November 2018 09:09:29
Housing fitted.
Sticky Wickett
#442 Posted : 09 November 2018 09:11:09
From another angle.
Sticky Wickett
#443 Posted : 09 November 2018 09:26:54
I still have a little more work to complete the housing, but i decided to turn my attention to the starboard armoured box for the next part of this update.
I mentioned last week that these armoured boxes were fitted to protect the lookouts from aircraft fire. The order to fit these boxes was given on the 4th June 1943. Sometimes there would be one box, while other U-boats sported one on each side of the conning tower, U230 included.
The design of the boxes differed between boats; some had round edges, other sharp edges with the port box further forward than the starboard one. The excessive weight of these boxes reduced stability of the U-boats in high seas. As a result an order to remove the boxes was placed on the 30th October 1943, so they were only in use for 5 months. However, some boats did retain the boxes long after the order was issued.
The attached photo shows U230, which my model is based on, in 1943. You can clearly see the armoured box on the upper side of the conning tower. If you look really carefully at the armoured box you can just make out the 'laughing swordfish' emblem of the 9th flotilla of which the infamous U96 also belonged. However, when this photo was taken in 1943, U230 was no longer based with this flotilla and should of changed the emblem to be inline with it's new flotilla, but was allowed to keep the 'laughing swordfish'.
Sticky Wickett
#444 Posted : 09 November 2018 09:27:44
Adding the uprights to form the box shape.
Sticky Wickett
#445 Posted : 09 November 2018 09:28:17
From another angle.
Sticky Wickett
#446 Posted : 09 November 2018 09:29:23
Horizontal base added, aligned with the deck of the conning tower.
Sticky Wickett
#447 Posted : 09 November 2018 09:30:01
Further horizontal supports added.
Sticky Wickett
#448 Posted : 09 November 2018 09:31:07
Looking from inside the conning tower.
Sticky Wickett
#449 Posted : 09 November 2018 09:32:48
Well that concludes my update for this week.
Thanks for looking in and your comments, have a great weekend and happy modelling!BigGrin Cool
Phil W.
#450 Posted : 09 November 2018 10:39:01
Lovely progress Phil, all looks great....Drool Drool
Sticky Wickett
#451 Posted : 09 November 2018 11:16:19
Thank you Alan!Cool BigGrin Lots of referencing and cross-checking against the only two photos I have of U230, which themselves are small black and white images, so progress has been slow but steady. Please with the results so far.
Phil W.
#452 Posted : 09 November 2018 11:33:54
Looking better and better, great work.
Sticky Wickett
#453 Posted : 09 November 2018 14:07:56
Thank you Graeme!BigGrin Cool Slow but steady progress.
Phil W.
#454 Posted : 09 November 2018 15:25:02
Great work as usual Phil, the detailing is superb.Love
Sticky Wickett
#455 Posted : 09 November 2018 16:48:38
Thanks Mark!BigGrin Cool . Just takes a bit of time to get it looking right when I have only two photos to reference.
Phil W.
#456 Posted : 15 November 2018 21:03:40
Cool Looking fantastic Phil great attention to detail BigGrin Drool
Sticky Wickett
#457 Posted : 16 November 2018 09:03:39
Thank you very much Ian!BigGrin Cool
Phil W.
Sticky Wickett
#458 Posted : 16 November 2018 09:10:16
Good morning from 'The Dockyard'.
In this weeks update i turned my attention back to the port armoured box, located just forward of the radar mast housing.
As i mentioned in previous posts, the armoured boxes were built to protect the lookouts from aircraft gunfire. The starboard box, being larger, could accommodate up to 5 crew members in the event of an aerial attack, while the port armoured box was much smaller and could accommodate only one crew member.
The attached photo shows the port armoured box part way through its construction.
Sticky Wickett
#459 Posted : 16 November 2018 09:10:51
A side on view.
Sticky Wickett
#460 Posted : 16 November 2018 09:14:13
The attached photo shows the underside of the radar mast housing fitted with a tapered section to blend it into the conning tower. This was based on the only b/w photo i have showing the port side of U230's radar mast.
This page was generated in 0.150 seconds.
